Thanks for the post ~Red, in regard to my rudder control servo i will be using a high torque high speed metal geared servo , from the 8th scale IC Cars ( so real large servo )
Alright for todays update on the build..
Got a load done made up for a lost day yesterday OK so first off trip down to the local builders yard.. purchased a few sheets of Chinese marine ply 3.5mm & 9mm both 8x4 sheets total spend £30, both sheets are for a few builds not just this one to be honest i only needed a 4x2 sheet of 3mm ply to do whats required to finish this project but buying in bulk is cheaper at the local yard.
So first job today....
Make up the remaining templatesMaking the templates required using some of the original super structure parts then modding them for the boat using some common sense and lots of pics for references( working from a plan is pointless with this conversion) Seeing how this huntsman is the 31 theres a issues with converting this to a 28 , the hull is quite long and the transom deck section is longer then it should be meaning that the super structure is no longer going to be accurate. something i should have though about way earlier.
Its not all bad... it will actually look like a hybrid 28 being longer will also make the boat sleeker to the eye, well i hope it does or this will hit ebay the moment its finished....
Next up is the transfer the templates to the 3.5mm ply & cut them out
At this point i have to work from the inside out because of the superstructures internal open deck detail, this included cutting a section out of the bulkhead support which will house the store section on each side
Now slot all the parts together for a dry fit
Tomorrow i will be cutting out the side sections for the exterior which will inc the cabin itself, the floors for the rear deck area & the servo/seat at the rear. At this point its easier to get the super structure built allowing me to work the internal gubbins of the boat without changing everything later as well as not causing any damage to the hull while its in its current 'fragile' state
And that concluded tonight work next post in a day or so.
