Author Topic: THE HYDRA...RACE BOAT FROM THERMOCOL AND PAPER  (Read 3194 times)
rathikrishna
« on: August 06, 2010, 06:12:10 am »
its my second speed model.its a double hulled one.it works nicely, but motor blows out after a long drive.i use a 12 volt Ni Mh battery pack, rated at 3000 Ma.so i need only a 5 volts, to run it.so i use a 7805 voltage regulator IC, with it and with this set up it will run over an hour, but i have to give intervals after a 10 minute ride...least for a two or three minutes.if not the small motor will heated up and at last it blows off...even though it works nicely...all super structure came from thick drawing paper, and radio,took from a toy car,its steering mechanism took from a CD lens drive mechanism.
kiwi
Re: THE HYDRA...RACE BOAT FROM THERMOCOL AND PAPER
« Reply #1 on: August 06, 2010, 07:41:43 am »
Absolutely brilliant - a job very well done.
That's truly the spirit of modelling.
Would like to see more of your models
cheers
kiwi
rathikrishna
« Reply #2 on: August 06, 2010, 07:55:32 am »
thank you sir...here i am a newcomer...i will post all of my works here and hope can get many good things from others...its hard to post all...because i have compleated more than 300 + models...i will try...
Page created in 0.014 seconds with 19 queries.
