Author Topic: Increasing 2.4Ghz Range  (Read 4558 times)
ray t
« on: August 14, 2010, 09:01:32 pm »
Been trying to figure ways of extending the range on my ongoing project which I will be using 2.4ghz radio gear.  Whislt searching, I came across this:
http://cgi.ebay.co.uk/Wireless-2-4GHZ-WIFI-Antenna-Booster-WLAN-RP-SMA-9727-/190429495441?pt=UK_Computing_Networking_SM
What do you reckon, think it will increase my max range if I can connect it to my rx?  I suppose for the price it might just be worth a punt
Re: Increasing 2.4Ghz Range
« Reply #1 on: August 14, 2010, 09:13:03 pm »
What sort of range are you looking for ?
Arrow5
« Reply #2 on: August 14, 2010, 09:20:19 pm »
Most modern radio systems have a range in excess of 1000 mtrs.  Very difficult to see your model at that distance, what are you flying?
..well can you land on this?
ray t
« Reply #3 on: August 14, 2010, 09:52:52 pm »
Half of that would be more than enough.  Oh well, anyone want to buy an 2.4ghz range extending aeriel  {-)
Bunkerbarge
« Reply #4 on: August 14, 2010, 09:53:39 pm »
I've tested my Spektrum dx6i 2.4 to a point where I can't distinguish which way the model is going anyway so I really can't see why anyone would want more.
I guess if you are flying a 1/4 scale Lancaster bomber it might be something to consider but as I would only have to walk a lot further to pick the bits up I'd rather stay closer anyway.
« Reply #5 on: August 15, 2010, 09:27:58 am »
Thats what I was getting at, no point having the model that far away you cant see it. :-))
FullLeatherJacket
« Reply #6 on: August 15, 2010, 09:30:35 am »
Ray
I think you'll find that this gizmo is intended to be connected to the transmitter, not the receiver.
FLJ
« Reply #7 on: August 18, 2010, 10:59:00 pm »
Yes, it looks like a TX "improver".  Probably make it illegal, I imagine that the DTI rules specify a max radiated power, and the TXs as supplied will probably be at that limit.
snowwolflair
« Reply #8 on: August 18, 2010, 11:51:17 pm »
ITs for a different part of the 2.4Ghz spectrum, wont do much for you.
Klunk
« Reply #9 on: August 19, 2010, 07:24:08 am »
For your info, this is an arial to be fitted to an existing wi fi router. Some basic routers do not have ariels on them and this gives them extended range upto 100 meters. I would never add this to an existing tx as I would be sure it was designed for that function.
full time penguin
BigAde
« Reply #10 on: April 07, 2011, 05:34:00 am »
Some 2.4 radios let you change a setting to U.S. where their laws for 2.4 power output are greater giving you more range! I know my Spektrum has this setting. Just a thought!
Page created in 0.255 seconds with 22 queries.
