Author Topic: Oil Water Separation Tank  (Read 2931 times)
UKJonathan
« on: August 21, 2010, 11:10:15 am »
Hi can someone tell me if you are running two engines, side by side do I need two oil separator Oil Separation tanks or can they be piped into one?
thanx
Jonathan
kno3
Re: Oil Water Separation Tank
« Reply #1 on: August 21, 2010, 12:10:34 pm »
One is enough, but make it twice as big  ok2
UKJonathan
« Reply #2 on: August 21, 2010, 01:04:31 pm »
Hi thanks for reply, I thought it should be and it is a decent size, but thought I would ask others just to confirm this
Jonathan
« Reply #3 on: August 21, 2010, 01:18:17 pm »
Jonathan....all things being equal.....if you are putting steam @ approx 150 degrees C into the displacement lubricator & hence into your engine....the exhaust steam + residual traces of oil will be @ approx 85 degrees C
The swirling action created within the inlet tubing to the seperator + the temperature reduction causes the oil mist to recondense as liquid & allows approx 80% the steam to be vented to atmosphere
A ratio of [10:1] eg., ......1000 ml boiler capacity to 100 ml seperator capacity...could be considered OK.......
So it is the total units of steam used & consumed...irrespective of the number of engines used...... O0 .....Derek
flashtwo
« Reply #4 on: August 21, 2010, 02:12:01 pm »
Hi Jonathan,
I've just built and fitted an oil separation cylinder/feed heater for my flash steamer "Vital Byte", which is powered by a Stuart D10 as you may remember.
I've placed a description of the device under the Flash Steam Control thread accompanied with a couple of photos.
Ian.
Page created in 0.123 seconds with 22 queries.
