Author Topic: Materials for steam engine  (Read 11967 times)
HelgeBe
« on: August 22, 2010, 11:37:03 am »
Can someone explain why the combination of brass and bronze is the preferred materials for a modell steam engine?
HelgeBe
Re: Materials for steam engine
« Reply #1 on: August 22, 2010, 12:04:16 pm »
Cos they don't rust and rot when subjected to steam and water like Steel and Alumininininium. And boilers are made from Copper for similar reasons.
  Regards  Ian.
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
« Reply #2 on: August 22, 2010, 12:33:46 pm »
HelgeBe
They aren't by model engineers, manufacturers prefer them because they are CNC'd easily and will last for years and years without more in-depth maintainence that cast iron and steel require.
Steel and cast iron, if not kept lubricated and clean can corrode, and aluminium is not considered 'right' in model steam- that said Graham Industries TVR series of engines are made of brass and aluminium and are very good little engines.
Greg
« Reply #3 on: August 22, 2010, 01:23:42 pm »
I always thought that copper was used for boiler tubes and boilers
because the thermal transfer properties were more efficient than
other metals.
HelgeBe
« Reply #4 on: August 22, 2010, 01:38:35 pm »
I believe I have read somewhere a statement that two parts in a modell steam engine that are sliding against each other should be of different materials, preferably one in brass and the other part in bronze. For example a piston in a cylinder. Is that so?
HelgeBe
Albion
« Reply #5 on: August 23, 2010, 11:04:42 am »
standard engineering practice is to have differing hardness materials, can be same family but different hardness. Having brass and bronze is one way of doing it. They dont tend to "Gall". Galling is when similer materials literally bind themselves together.
gondolier88
    • Coniston Regatta
« Reply #6 on: August 23, 2010, 08:55:44 pm »
Galling is one reason- however the main reason is that as the cylinder wears a it can be re-honed lightly and new pistons made at a low cost, rather than having hard pistons that wear the cylinder excessively and require new cylinders.
Greg
ooyah/2
« Reply #7 on: August 23, 2010, 09:37:43 pm »
Hi Greg,
You have changed your mind !!!!
What about your determination to make cast iron pistons in your first engine build, or has somebody put you wise, are you now making them with another material.
George.
gondolier88
    • Coniston Regatta
« Reply #8 on: August 24, 2010, 06:24:37 pm »
Hi  George,
No- I said that pistons should never be harder than the cylinder, not that they shouldn't be the same hardness- plus with my machining tolerances I doubt I'll have any wear :((!!!!!!
Greg
ooyah/2
« Reply #9 on: August 25, 2010, 12:08:39 am »
Greg,
I am really not bothered as to what you make your pistons from it's your choice, I told you by P.M. the reason for using Brass or Cast bronze as it's much easier to make new pistons than to bore out a barreled cylinder, I have only had to do it once and that was for an old friend who's D10 was about 50 years old and was run regularly ever Wed and Sat and it had the original brass Stuart pistons with graphite packing.
There is one thing for sure no mater how good you think that you can machine cylinders and pistons, with close tolerances they will wear eventually
and that's a fact !!!
Using cast iron for pistons isn't new the Loco guys have been doing it for years, as did full size ships.
I use cast iron in my Flash Engine and that's doing 15,000 rpm the metal is 70 ton mehanite grade cast iron for the piston and the cylinder
George
gondolier88
    • Coniston Regatta
« Reply #10 on: August 25, 2010, 07:47:46 pm »
Hi George,
I meant that with my (bad) tolerances they won't be touching each other any way so no wear would take place, not bragging about skills I presently don't have, or not all the time anyway.
Mine will be using proper steam cylinder oil and have two grooves in each piston, giving 3 strips of 1/6" touching the cylinder wall, I'm really not worried about it knowing that there are thousands of steam engines running at far faster piston speeds than my little D10 that do very well indeed- including SY Gondola's for that matter- run every day for 7 months of the year for the last 30 years, and only very slight wear to show for it- wet steam and plenty of cylinder oil does the rest.
Thanks for your advice, noted, but graciously ignored, on my head be it.
Greg
Greg
ooyah/2
« Reply #11 on: August 25, 2010, 11:46:45 pm »
Hi Greg.
Never at any time on the forum or in P.M. have I questioned your machining or suggested that you were boasting.
It is your prerogative to ignore advise and as it would appear that I have offended you I will refrain from offering it again.
George.
gondolier88
    • Coniston Regatta
« Reply #12 on: August 26, 2010, 06:50:06 pm »
Sorry George, no not at all, you havn't offended me!
Not sure how I gave that impression, but I'm sorry I did, and please don't stop advising me- I'm very grateful, but that doesn't mean I am always going to act on it.
Greg
ooyah/2
« Reply #13 on: August 27, 2010, 12:45:48 pm »
Hi Greg,
Nobody likes to be told their advice will ignored graciously or other wise and from that statement it appeared to me that you were offended.
Advice is given and it's the prerogative of the recipient to use it or not, but not to be told that it would be ignored.
However it takes a man to apologise and your prompt apology is accepted, the decks are now cleared as far as I am concerned.
What I was trying to get over to you is that no mater how good an item is machined if it's sliding against another  it will wear, oil or no oil, which you concede that Gondola's pistons have slight wear, slight though it may be it's still wear and a credit to the manufacturer that after 30 odd years the wear is slight.
The reason for full size pistons and cylinders being cast iron is that casting process is much easier and economical that of any other material although some of the big engines had steel pistons.
You say that with your (bad) tolerances they will not be touching, well what will happen is that the gases will pass the piston and give poor power results and large steam consumption but a beautiful column of steam from the exhaust as no amount of steam oil will seal between the cylinder wall and the piston.
Why not make new pistons and fit them with Silicone "O" rings which make a good seal and if your piston tolerances are a bit out the rings will take up the slack., you could even use graphite packing to make a seal, Gondola's pistons will have rings fitted which can be replaced if required without making new pistons.
You then go on to say that your pistons will be touching the cylinder wall which I assume you mean that the piston will be size for size with the cylinder wall
if so  size for size doesn't work it will seize. .
D10' can rev up to 2000 rpm but in a model launch I would think more in the range of 800-900 and I don't think that Gondola will be any where near that but I am sure that you could let me know what it revs at cruising speed are.
I hope that my observations are of help to you in the building of your engine.
George.
gondolier88
    • Coniston Regatta
« Reply #14 on: August 27, 2010, 06:39:34 pm »
Hi George,
I believe you don't quite get my sense of humour, or it doesn't come across in my posts- either way, I was intimating humourously that my machining skills were not upto the standards of yourself for example, but apart from machining them, I have a very extensive knowlege of steam engines and their running characteristics.
As such I am well aware of the running clearances of pistons in cylinders, and mine are ok, if perhaps slightly on the larger side- If I get problems with large steam consumption then I will know how to remedy it, but for the moment I will stick to the ones I have machined.
Gondola's engine was rebuilt by Roger Mallinson, one of the best small marine engineers in the country, as such the 'wear' is less than 0.0015". She runs at a cruising speed of 7/8mph @ 180-200rpm, max 12.7mph@380rpm.
She has a bore and stroke of 8" X 9"- giving a piston speed @200 rpm of 1800"p/min
My D10 has a bore and stroke of 3/4" X 3/4", and will be running at a cruising speed of 450rpm, giving a piston speed of 337.5" p/min- nowhere near what Gondola's is, and producing far less power and torque is incomparable for a point of view of wear.
I do like the idea of Graphite packing though, and I understand it used to be used frequently by Stuarts in their engines?
Greg
ooyah/2
« Reply #15 on: August 27, 2010, 09:44:55 pm »
Hi Greg.
That's fine , thank's.
George.
steamboatmodel
« Reply #16 on: August 29, 2010, 02:20:51 am »
Hi Greg,
"I do like the idea of Graphite packing though, and I understand it used to be used frequently by Stuarts in their engines?"
I have never used it on model engines, but have packed and repack many a gland with it on full size equipment. I covers your hands and everything you touch with ether black or small flakes. The ideal setting with it was when you got the drip rate down to 10 drops a minute with out the packing scorching. If it scorched you had to remove it and start over from the start. We loved it when new equipment came in with O ring seals.
Gerald.
gondolier88
    • Coniston Regatta
« Reply #17 on: August 29, 2010, 08:57:57 am »
Hi Gerald,
Yes, we use it at work all the time, but I've never used it, or seen it used in as a piston ring before, I was wondering how successful it was in that role?
Greg
HS93 (RIP)
  • I cannot spell , tough
« Reply #18 on: August 29, 2010, 09:36:39 am »
Stuart and Reeves specified it for a long time in the past.
Peter
MONAHAN STEAM MODELS
« Reply #19 on: August 30, 2010, 12:41:12 am »
A couple of our full sized small steam duplex pumps use the stuff for the rings on their steam side. I can't remember off the top of my head but I think one pump has 2" pistons and the other has 3". Seems to work well. However on the larger steam pumps and engines we have, those all use cast iron rings.
Nick
« Reply #20 on: August 30, 2010, 07:21:52 am »
Guys...experience from years ago was that carbon/graphite filled woven "James Walker" Lion Brand Packing [in the big silver box] was more than suitable for near static applications including the rising spindle of a steam valve, but suffered when installed in dynamic applications   >>:-( <*< ....Derek
gondolier88
    • Coniston Regatta
« Reply #21 on: August 30, 2010, 08:02:27 am »
Thanks guys,
I had nevr heard of this before- I supose Derek the modern equivalent which does work in dynamic situations is PTFE gland packing?
Greg
steamboatmodel
« Reply #22 on: August 30, 2010, 06:05:39 pm »
Up here it was in a dark red box with black printing I can't remmember the brand name. It was mostly water circulation pumps with anything from a one to a twenty hoursepower electric moter driving them. The valves were never a problem they were static applications, it was the rotationg shafts and adjusting the glands that caused headackes, You had to be ambidexterous to do it properly, you had to lean over the rotating shaft (2000RPMs) with a wrench in each hand and tighten up the gland nuts evenly.
Gerald.
