Author Topic: What thickness window plastic?  (Read 3900 times)
Nige52
« on: August 25, 2010, 07:41:30 am »
Due to a careless over-spray which I can't get at...... %)
I have decided to remove all the plastic/acetate window glass from my new to me Police launch and replace it with brand new shiny stuff, but looking on the auction site there are lots of different types and thickness's, most of it is advertised in Microns...could somebody advise me what thickness will be suitable please?
Nige
Re: What thickness window plastic?
« Reply #1 on: August 25, 2010, 08:27:15 am »
Nige,
It depends on the shape.
If it has to be bent round corners the thinner ones are better.
If it is just square frames it doesn't matter much as you can hardly see the thickness.
Nige52
« Reply #2 on: August 25, 2010, 09:07:01 am »
It's all flat sheet, but I don't want to buy some then find it's flimsy cellophane that you buy birthday cards in  :}
Most of it is advertised as 220 or 225 microns....I know that's about a quarter of a mill, but I can't visualise it... :-)
« Reply #3 on: August 25, 2010, 09:20:58 am »
Have a look at this, it will probably help.
http://www.cornwallmodelboats.co.uk/acatalog/acetate-sheet.html
0.5mm to 1.0mm will probably do you.
« Reply #4 on: August 25, 2010, 10:49:49 am »
Hi Nige
Buy your wife a nice big box of Chocs in clear plastic and ask for the box back.    8)
Ken
« Reply #5 on: August 25, 2010, 10:56:02 am »
Cheaper to buy the plastic and keep your head down Ken. ;)
pugwash
« Reply #6 on: August 25, 2010, 11:07:36 am »
I hope your wife isn't reading this Dicky <*<
Geoff
« Reply #7 on: August 25, 2010, 11:12:24 am »
You hope Geoff %)
« Reply #8 on: August 25, 2010, 12:09:18 pm »
Buy a bottle of "Rola-Cola" from the local supermarket, open and throw the contents away, slit and cut to size. You can get coloured containers too  O0
  Regards  Ian.
triumphjon
« Reply #9 on: August 25, 2010, 02:23:14 pm »
for most of my windows i use 1mm clear plasticard , i find its stiff enough not to want to fall out of the frames at the first puff of wind at the lakeside !
Fifie
« Reply #10 on: August 25, 2010, 03:35:56 pm »
Take a sheet of acetal presentation slide material
Laminate it inside a laminating pouch
You can obtain both in various micron scales
If you are crafty you can print an image ( Jimmy Buchan) on the presentation slide
or if you want print your own image
Fifie
« Reply #11 on: August 25, 2010, 08:58:03 pm »
Before slinging the contents, consider this.
http://www.nigella.com/recipe/recipe_detail.aspx?rid=13588
But if it was the diet muck, yes, sling the contents as a matter of good sense.
sentry
« Reply #12 on: August 25, 2010, 10:02:04 pm »
Hi Nige52,
 if you have a cake of blank Cd's there,s normally a clear disc each end or buy a few empty CD cases  only a few pence each.
                            Regards Sentry.
