Author Topic: New member after a train ferry model  (Read 3289 times)
ianwales
« on: September 08, 2010, 09:32:11 am »
Hello Everyone
I am new to this forum and have basically joined as a way of getting some help for a project I want to undertake, I am a Railway Modeller who is currently building a model based on Dover Marine station in Kent, but, the info I am after requires more knowlege of Model Ships rather than model railways at the moment.
One of the requirements for this layout will be a train ferry so I am on the lookout for a model somewhere in the 1/76th-1/100 th scale bracket of a train ferry or a stern loading ro-ro ferry that I can add the railway tracks to, I am looking for something along the lines of the Deans Marine kits MV Muirneag model, although this one is a bit expensive for what will become a glass dock mounted static model, that can be cut down to a waterline model and mounted in the dock to shunt the trains on and off.
Is there anything of this sort available or that can be adapted to a cross channel train ferry? I undertand there was a model of a Danish train ferry some years ago made by trinbaetett of aarhus, but, every other avenue I have tried has drawn blank so far.
Prophet
Re: New member after a train ferry model
« Reply #1 on: September 08, 2010, 10:46:10 am »
i've had a good look round and have only found pic's of train ferrys which you can google pretty easy, buying a kit of some sort thats not so easy... and given that the models going to be 'static' i would be hesedant to spend the best part of £300, i would be more inclines to search for a build plan costing around the £20 mark and scratch build it to your requirements, try here and see if there are any ships that might do the job
http://www.cornwallmodelboats.co.uk/acatalog/mmi_plans.html
at a guess.. i doubt you will spend more then £100-150 building it from scratch which is still excessive but better then 300!
Klunk
« Reply #2 on: September 08, 2010, 11:53:46 am »
any card modellers out that could help????
full time penguin
« Reply #3 on: September 08, 2010, 01:24:00 pm »
Check your PM Ian.  ;)
barriew
« Reply #4 on: September 09, 2010, 07:27:36 pm »
The October Railway Modeller has an advert for a paper kit of a Train Ferry.
Barrie
ianwales
« Reply #5 on: September 11, 2010, 09:24:32 pm »
Hi Barrie
Thanks for the heads up on the RM advert, not quite what I am looking for, more of a cross channel type ferry is what I am after.
Page created in 0.013 seconds with 21 queries.
