May 09, 2025, 01:17:22 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Mayhem at Wicksteed -
May 24 25
Home
Help
Search
Calendar
Login
Register
The Shipyard ( Dry Dock ): Builds & Questions
Steam
Le Lechalas
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Le Lechalas (Read 5028 times)
KBIO
Guest
Le Lechalas
on:
September 10, 2010, 09:14:05 pm »
Hello!
Just to show you this boat ( from after war) that was built for civil works engineers working in inspecting the canal from Nantes in France.Originally on steam, she has been fitted w/ diesel engine later on. The boat has been given to an association that stores it! Sailing from time to time though!
Today was good day for sailing,so...
First = iside. But I'll change the engine PM Research (too big) for an oscillating Stuart . Regner Boiler/ double burner. Gas regulator Anton. Gas tank regner. Propelle : Raboech 70mm.
Uploaded with
ImageShack.us
Sailing ! I forgot to put some weight on the back (stayed in the car
Uploaded with
Uploaded with
ImageShack.us
tp://imageshack.us]ImageShack.us[/URL]
Detail of the deck.
And the real one. The photo is not very well taken!
Uploaded with
ImageShack.us
Regards!
kiwimodeller
Full Mayhemer
Offline
Waihi, New Zealand
Re: Le Lechalas
Reply #1 on:
September 11, 2010, 01:11:35 pm »
Great looking model did you build it from the original plans or is it a kit that you modified? Why do you need to change the PM engine? I have put one in a boat for a friend and another friend also has one and both seem to go very well with 70mm props. The engine is very easy to control and runs well on just a little throttle so I was surprised that you need to change it. Cheers, Ian.
KBIO
Guest
Re: Le Lechalas
Reply #2 on:
September 11, 2010, 08:43:08 pm »
Good evening Kiwimodeller!
This boat is made out of a plan founded in a revue "Chasse Marré" 's middle page & enlarged up to +/- 125cm.
The only reason why I pulled out the PM is because it has a lot more power (9.3cc) that I need for this model.
I replaced it w/ the Stuart oscillating (4cc?).See the shape of the hull= I do not need power to go ahead.
Uploaded with
ImageShack.us
I moved the PM in my Boston Typhoon which is twice more heavier. I have plenty power there too but it is more appropriate.
Like you I find this engine very reliable and running very good w/ no leak. Running slow with a wisper or full blast, it never fails. On top of it the price is very friendly.
kiwimodeller
Full Mayhemer
Offline
Waihi, New Zealand
Re: Le Lechalas
Reply #3 on:
September 12, 2010, 11:30:41 am »
I agree, the PM V Twin is very good value for the money. Since I bought my one two of my friends have asked me to get one for them. Mine ran very well but since I tried the trick that was posted earlier (from Nick Monahan I think) of mixing some graphite powder with the steam oil in the lubricator it is even better, it will run almost at an idle speed and if I stop it will start straight away once I give it just a little throttle. You do not have to put the Graphite in every time, just occaisionally. Cheers, Ian.
KBIO
Guest
Re: Le Lechalas
Reply #4 on:
September 12, 2010, 09:28:07 pm »
Good evening!
You are right Kiwimodeler! I've seen a post where N.Monahan recommands to use 25% graphite in the oil. I'll do that , at least for the break in.
Cheers.
KBIO
Guest
Re: Le Lechalas
Reply #5 on:
March 24, 2011, 05:58:30 pm »
Hello!
Today was a nice day!
First sun burns near the water.
I took this oportunity to sail may Lechalas. I change the motor for an oscillating Stewart. The boiler Regner is good.
min to achieve 1.8 bar. 20 min autonomy. no problem = boring!
Regards!
http://www.youtube.com/watch?v=UFfprsMrR7g
http://www.youtube.com/watch?v=qcYv0m8bJbg
http://www.youtube.com/watch?v=z7aCJCT_yFY
http://www.youtube.com/watch?v=kqesDcUbtnE
Bernhard
Guest
Re: Le Lechalas
Reply #6 on:
March 25, 2011, 06:03:05 am »
hi.............
a great boat you have there....look so real,,,..super Duper...what a fine work you have don there,,,,,,,,,,,,,,,,,,,,,,,,
Regards Bernhard
john s 2
Full Mayhemer
Offline
Southend on Sea Essex
Re: Le Lechalas
Reply #7 on:
March 26, 2011, 06:55:31 am »
Is it a good idea to add Graphite during running in? During the running in period the working surfaces are
attaining there final better fit. Addiing Graphite at this stage will slow down this period . The reverse of
what you want. Yes use graphite but not to run in. John.
Print
Pages: [
1
Go Up
« previous
next »
Steam
Le Lechalas
