Author Topic: Help with Big CVN Enterprise?  (Read 3281 times)
« on: September 17, 2010, 06:43:46 pm »
Via email to Mayhem...
Hi Martin,
...... I write because what I'd really like is a 'huge' aircraft carrier kit cut for me. I was in process of arranging one some time ago but the guy turned out to be a crook. Your site seems reputable enough, so I going to try again. When I say huge, I mean a flight deck cut from a sheet of 4'X8'X1/8" ply wood. I plan to embed a solar panel in the deck and although not a scale feature, it’ll be good enough as the model itself will only be 'stand way off semi scale. I'd like it styled on the lines of the 'Big E  US CVN Enterprise.
I will need the frame, superstructure, other important parts and plans cut; planking and deck I'll get myself. I think four of the largest motors available should be enough power. 4, five inch, five bladed props and a hull full of car batteries should make for quite an impressive model-yes? If eight feet is too ambitious, I'll take six feet; still an impressive bit of work.
 If at all you can help me with this, I'd appreciate it.
Calvin.
cos918
Re: Help with Big CVN Enterprise?
« Reply #1 on: September 17, 2010, 10:35:25 pm »
one of the American hull manufacturers do a hull for an aircraft carrier and plans  . Sorry can not remember there name but it was a lot of money
Flying Sparks
« Reply #2 on: September 18, 2010, 09:13:56 am »
Sounds a bit strange, he does not even a plan but he wants the wood cut out????? He does not even know how big it will be but wants to put 4 x 5" props into it and fill the hull will car batteries!!! It might even be 8 feet long, if not 6 feet long.
Huh?
Phil.
Arrow5
« Reply #3 on: September 18, 2010, 09:38:54 am »
Is this for another cross Atlantic/Pacific attempt ?    :o :}
..well can you land on this?
hmsantrim
« Reply #4 on: September 18, 2010, 10:54:45 am »
Hi Martin.
               is a bit of money to buy and a big beast but can get a GRP hUll here.
               http://scaleshipyard.com/Catalog%20Pages/carriers.html#WHU-V 5
                          cheersd Frank
ayrshire andy
« Reply #5 on: September 18, 2010, 11:29:00 pm »
Hi Calvin,
Congrats first of all for attempting what will be a fantastic model, to save u both time and money, does it have to be scale? If you are prepared to spend a few days with the graph paper u could design a STEALTH carrier composed entirely of flat ply panels which you could take to a local manufacturer with a 3-axis CNC router who will produce the hull, internal structure, deck, tower etc as a flatpack for u to build and then add commercial fittings to taste...sure the company may charge a bit but the a few sheets of 6mm ply and 1 sheet of say 12mm for internals ex hardware store would be economical and give you a head start on the build AND a striking appearance...best wishes my friend whichever cat-skinning method you choose! :-))
Ayrshire Andy
Page created in 0.017 seconds with 22 queries.
