Author Topic: plank bender tool needed  (Read 5665 times)
batesyboy
« on: September 23, 2010, 11:14:47 am »
Hy all, my 1st post hope you can help !
Been looking at electric plank benders , could find the amati 7205 and
 been looking for one in micro-models but couldnt find or if i did , it seemed to be a manual 1 which you move pegs to form the required shape  after damping planks .Am i safe with the amati electric bender or can any1 give me other options  cheers  :-)) :}
pugwash
Re: plank bender tool needed
« Reply #1 on: September 23, 2010, 11:24:47 am »
Batesy, here is another option.
Geoff http://www.expotools.com/store/pages/products/index/pdf/p53.pdf
***space inserted to make link work by TT***
In case you were wondering what the edit was.
« Reply #3 on: September 23, 2010, 12:33:18 pm »
« Reply #4 on: September 23, 2010, 12:42:12 pm »
Guys........these electronically heated fine plank benders do just that.......they  HEAT THE WOOD...however must rely on a residual moisture content within the wooden plank  for it to bend....or  >>:-( the plank will break....or crack after it has been installed  O0
The alternative to this is to add moisture over a relatively longer period of time [30 minutes] to the planks prior to bending
One method is steaming the planks in a simple pot of water on the stove.........Derek
pugwash
« Reply #5 on: September 23, 2010, 12:59:49 pm »
Whoever put the edit on my reply - Thankyou - I wondered what I was doing wrong.
Geoff
Popeye
  • I see no ships!
« Reply #6 on: September 23, 2010, 01:26:46 pm »
My plank bender comprises a 4 foot lenght of plastic waste pipe sealed at one end and with a removable cap to fit the other end  - see photo - (all fittings courtesy B & Q or similar outlet). I'e also got a 2 foot version for use with short planks.
Planks are inserted into the tube, fill with common household ammonia (always do this  in the open air and use rubber gloves and eye protection) following which the open end is capped. After  approx. 15 minutes remove planks one by one, rinse in cold water - in the open air - then pin/clamp in situ to dry thoroughly (always position a pair, one each side of the hulll, to  eliminate the risk of warping or otherwise stressing the hull). When dry the planks will conform to the hull's curvature where they were positioned when wet,   and can then be permanently fixed
I've found this method ideal for all common dimensions of 'modelling' stripwoods, including 3/8th  x 1/8th  cedar planking used on my current scratch build square rigger .
Confucius he say, 'if all else fails.......reach for the  Red Top-Stop'.
batesyboy
« Reply #7 on: September 23, 2010, 04:48:23 pm »
wow  thx all   what a great site   and great ideas
especially like the saucepan   :} no chance of me doing that
with my missus lurking in the background  if she saw me doing that
she`d push the electric bender somewhere the sun dont shine
let you know my decision all
great site pugwash
