Hi
I'm building a Arun class boat. I need a Y boat. How did you get on building yours???
Bill,
I'm nearing the end of my Y boat, and it is looking very neat. It's a nice kit. I've not used moulded styrene parts before and so it was a bit daunting to start with, but it goes together well. At least Adrian supplies good instructions for this kit!
One tip; when you seal the top and bottom halves of the hull together and fill the joints, the tubes become air-tight. When you then sand them down with wet and dry, using warm water like I did, the air inside expands and splits the join! Second time around I drilled a small vent hole at the bow, low down inside, now hidden by the spray cover, to solve the problem.
It's just getting it's last coat of paint. I'll post pictures as soon as it's done.
Chris
