Author Topic: Best way to make a hull  (Read 5821 times)
chris holley
« on: October 03, 2010, 07:57:04 pm »
Iam looking to make a ship about 1000mm not to big. I would like to know which is the best way to make a hull? its basiclly a box iam after like the car transporters (not ferry). the bottom off the hull is flat, the stern is vertical an the bow is taperd an 40% vertical. the bridge is not very high 2 storys.
a basic boat really just dont no how i should build the hull many thanks chris :-)
Re: Best way to make a hull
« Reply #1 on: October 03, 2010, 08:26:03 pm »
Just look for a copy of a Model Boats magazine with one of Glynn Guest's plans featured, preferably a cargo type.  You will find all the construction details you need - it will just be a case of re-shaping and re-sizing, but the construction methods will be common to all.
chris holley
« Reply #2 on: October 03, 2010, 10:12:15 pm »
been looking around the net cant see much which looks like what iam after from glynn guest {:-{, maybe someone can help. dont think it will be a big job something to keep me busy while my local pond is being empteyed, cleaned an then nature is left to fill it. a month or two.
An iam up for trying something diffrent rather than buying second hand, no fun in that. :D
chris
« Reply #3 on: October 04, 2010, 05:10:54 pm »
If that's a picture of the type of hull you are after, then you could literally build a box, starting with a frame work and then sheeting the sides. The bow could be made from block balsa or some such and the whole thing covered in fibre glass tissue and resin. I suspect the prop is either in a tunnel or the hull is stepped at the stern below the water line.
HTH
Doug
chris holley
« Reply #4 on: October 04, 2010, 07:00:45 pm »
Ok, when you mean make a box just piece off wood screwed to the sides an back sand down an float :((?
« Reply #5 on: October 04, 2010, 08:28:22 pm »
Glued, rather than screwed.  This tends to be more water resistant, which is a good thing on a boat.  Paint can also be useful for keeping the water on the outside, although dougal99 did say "starting with a framework and then sheeting the sides".  The articles that accompany the free plans usually give a plentiful supply of hints and tips to get any beginner who cares to read them into building simplified hulls.
Despite you being unable to find precise instructions for the exact hull that you want, the fact remains that the simple box-type hulls all follow the same general method, you know one, you know them all.  Its just the sizes of the panels that changes.  Adding your chosen details to make it into the ship you want is another story.
chris holley
« Reply #6 on: October 04, 2010, 08:36:20 pm »
ok, still seems hard for me {-) will look for a plan off a box an see what comes up
Arrow5
« Reply #7 on: October 04, 2010, 09:24:49 pm »
You could try carving some builder`s insulation foam to shape or build the box out of 1" foam sheet with blocks at bow and stern shaped to suit. Cover with pasted-on brown paper then painted.  Waterproof paste of course.
..well can you land on this?
chris holley
« Reply #8 on: October 04, 2010, 09:44:41 pm »
so make box with out sides???
then add sides an bow???
then deck paint an a simple box ship is there!
am i right?
« Reply #9 on: October 04, 2010, 10:04:09 pm »
And a stern.  Vital.
Arrow5
« Reply #10 on: October 04, 2010, 10:48:42 pm »
Box without a lid then add back bit(stern) and pointy bit (front or bow).  The "lid" would be the "deck" as it is called.  You forgot to paste the brown paper on the foam to protect it (the foam) from the paint which would dissolve the foam..
Drkomen86
« Reply #11 on: October 04, 2010, 11:20:37 pm »
not sure if it will help,
cut yourself a few bulkheads from plywood as in top left corner positino them upside down on a flat surface and secure them verticaly, when there all in place apply flat sheets thin plywood to the bulkheads and wait for them to dry. after all that is done place a large block of blue builders foam to the front and sand it to shape. then your ready to start your deck.
Hope this helps  :-)
Timo2
« Reply #12 on: October 05, 2010, 08:57:13 am »
Hi Chris
    Have a look at   :-))
       http://www.modelboatmayhem.co.uk/forum/index.php?topic=26445.msg260035;topicseen#msg260035
        just make it bigger
   Timo2
   P.S.  Meekat speak  ssimmple    O0
Page created in 0.213 seconds with 21 queries.
