Thanks for the replies.
My terminology may be over the place as I assumed a mould was a hollow female boat shaped thing into which you put the fibre glass, hence I can see that it needs to be perfect and smooth so the outer skin of the hull is perfect, but I guess that you make the female mould by building a perfect male plug..
I appreciate what you are saying about the exterior finish of the fibreglass if using a male plug. I do recall my father spending hours/days in the cellar with his power sander getting the hull sanded down correctly.
John, when you say gel coat, are you meaning lay up the matt to make the hull, let it cure then gel coat it to get it smooth and finished?
The Vietnam era monitors are quite simple hulled things (glorified Mike 6 landing craft). The model 1:24 scale so is about 30 inches long. I could use plywood, but reckoned glass would be more fun
Maybe not if the sanding process is going to be tiresome.
Assuming I use tape to seal the polyurethane, is it a case of apply resin, apply mat, soak mat, resin some more, roll out to get rid of excess and wait. Would one skin of mat do?
I will go and see Allscot ( it is years since I dealt with them) and get some advice from them also.
Thanks again.
All the best
Sandy
