Author Topic: RC 2.4GHZ trouble  (Read 2428 times)
Perks842
RC 2.4GHZ trouble
« on: October 10, 2010, 02:33:08 pm »
Hello all, I've just binded my rc set-up but when the boat is ON and then I turn on the controller the motors go mad but the controller has no effect, but the motors dont go mad until the control is turned on.   Any ideas?
barriew
Re: RC 2.4GHZ trouble
« Reply #1 on: October 10, 2010, 02:38:46 pm »
What sort of ESC are you using? If its an Mtroniks, then you need to set that up as well.
Barrie
Perks842
« Reply #2 on: October 10, 2010, 02:45:57 pm »
viper
barriew
« Reply #3 on: October 10, 2010, 02:49:22 pm »
First turn on the TX, then the RX. The two leds on the viper (red & green) should flash. Press the set-up button. The green led comes on. Set the Throttle control full forward, the Red led comes on . Set the throttle full reverse. The ESC is now set up.
Hope this helps.
Barrie
Perks842
« Reply #4 on: October 10, 2010, 03:12:22 pm »
when I turn on the power the LEDs flash but when i push the button they both turn off, no green or red.
Perks842
« Reply #5 on: October 10, 2010, 03:16:49 pm »
LED's flash as long as i push the set up button before the motors go mad then the green come on solid, but no response when I hold the throttle forward.
Perks842
« Reply #6 on: October 10, 2010, 03:29:47 pm »
Found the problem, My receiver suggested channel 1 so tried it in channel 2 and worked straight away, thanks Barrie and all.
« Reply #7 on: October 10, 2010, 07:13:25 pm »
Conventionally on a 2 channel set, channel 1 is the rudder, channel 2 is the speed control.
With a Viper, you get about 2 seconds from switch-on to button press to get into program mode.
Perks842
« Reply #8 on: October 10, 2010, 08:48:03 pm »
the set said channel 1 for props 2 first rudder but all sorted so all good.
Page created in 0.091 seconds with 22 queries.
