January 13, 2026, 04:15:19 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Model Boating
RC 2.4GHZ trouble
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: RC 2.4GHZ trouble (Read 2760 times)
Perks842
Guest
RC 2.4GHZ trouble
on:
October 10, 2010, 02:33:08 pm »
Hello all, I've just binded my rc set-up but when the boat is ON and then I turn on the controller the motors go mad but the controller has no effect, but the motors dont go mad until the control is turned on. Any ideas?
barriew
Full Mayhemer
Offline
Thaxted, Essex
Re: RC 2.4GHZ trouble
Reply #1 on:
October 10, 2010, 02:38:46 pm »
What sort of ESC are you using? If its an Mtroniks, then you need to set that up as well.
Barrie
Perks842
Guest
Reply #2 on:
October 10, 2010, 02:45:57 pm »
viper
barriew
Full Mayhemer
Offline
Thaxted, Essex
Reply #3 on:
October 10, 2010, 02:49:22 pm »
First turn on the TX, then the RX. The two leds on the viper (red & green) should flash. Press the set-up button. The green led comes on. Set the Throttle control full forward, the Red led comes on . Set the throttle full reverse. The ESC is now set up.
Hope this helps.
Barrie
Perks842
Guest
Reply #4 on:
October 10, 2010, 03:12:22 pm »
when I turn on the power the LEDs flash but when i push the button they both turn off, no green or red.
Perks842
Guest
Reply #5 on:
October 10, 2010, 03:16:49 pm »
LED's flash as long as i push the set up button before the motors go mad then the green come on solid, but no response when I hold the throttle forward.
Perks842
Guest
Reply #6 on:
October 10, 2010, 03:29:47 pm »
Found the problem, My receiver suggested channel 1 so tried it in channel 2 and worked straight away, thanks Barrie and all.
Full Mayhemer
Offline
Blackpool, Lancs, UK
Reply #7 on:
October 10, 2010, 07:13:25 pm »
Conventionally on a 2 channel set, channel 1 is the rudder, channel 2 is the speed control.
With a Viper, you get about 2 seconds from switch-on to button press to get into program mode.
Perks842
Guest
Reply #8 on:
October 10, 2010, 08:48:03 pm »
the set said channel 1 for props 2 first rudder but all sorted so all good.
Print
Pages: [
1
Go Up
« previous
next »
Model Boating
RC 2.4GHZ trouble
