Pages: [1] 2 3   Go Down
Author Topic: A few steamy questions  (Read 17797 times)
SNOOPDOG32
« on: October 26, 2010, 07:59:54 pm »
Hello all
I am about to start my first steam plant and intend using it in a open launch i have been ready through the steam threads
and now have a Maccsteam 3 1/2 2 horizontal boiler and a Graham TVR1A engine.
I now want to get all the other bits for the plant. I know i will need a lubricator ,condenser and a radio control valve ,what ones and sizes do i need and where is the best place to purchase them!
Is it worth fitting a hand feed pump to the boiler?
Is it worth fittng extra lagging under the the boiler planking?
I am sure i will have many more questions as i progress with the build.
  Look forward to your answers  :-))
SNOOPDOG32
Re: A few steamy questions
« Reply #1 on: October 26, 2010, 08:35:55 pm »
Oh i also have a gas tank from maccsteam
can anyone recomend a good book also :D
firedup
« Reply #2 on: October 26, 2010, 09:03:12 pm »
Try "Model Marine Steam" by Stan Bray
Very good reference book
Mark
SNOOPDOG32
« Reply #3 on: October 26, 2010, 09:16:08 pm »
Thanks for that Mark found one on e bay  :D
ED
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
« Reply #4 on: October 26, 2010, 09:42:51 pm »
Sounds like this will be a nice boat when it's finished mate. Have you any pics of the hull- have you built it?
You will need an inline displacement steam lubricator, there are many places to get these- Steamfittings.co.uk Reeves 2000, Stuart Turner, Modellbau-niggel.de, Live Steam Models, Mainsteam Models- reading through the threads and a good google session should find you more- though theres plenty to start with there.
There are two trains of thought re. hand pumps- your boiler is a quick steamer and you should get a good 25-30mins steaming time with a full boiler- if this is good enough for you then leave it. If, like me, you feel that isn't enough and don't want the boiler to lose pressure and go cold by re-filling before having another steam then yes, a hand-pump will be necessary.
It is definitely worth fitting lagging under the boiler- again check out the suppliers listed above as some supply suitable lagging- 1.5mm Kaowool or similar would be fine and discreet.
If you have soldering skills you can make a condenser for far less money than buying one, and you can make it to a size that fit's the boat you are building.
Greg
SNOOPDOG32
« Reply #5 on: October 26, 2010, 10:13:20 pm »
Thanks for the info Greg still looking at hulls
What sort of size would the condenser need to be! i can solder so could have a go at making one
i have been reading through the threads for the past few months just want to check the best items
to use.Wil have a good google and see what else comes up there is quite a bit of choice out there!
ED
HS93 (RIP)
  • I cannot spell , tough
« Reply #6 on: October 26, 2010, 10:29:56 pm »
the larger one of these
Peter
SNOOPDOG32
« Reply #7 on: October 26, 2010, 10:48:50 pm »
Thanks Peter
Will have a go at making one i think %)
ED
HS93 (RIP)
« Reply #8 on: October 26, 2010, 10:57:37 pm »
do you know what the internals need to be like ? I can prob find a shetch
peter
SNOOPDOG32
« Reply #9 on: October 26, 2010, 11:05:18 pm »
I have seen them on here somewhere but if you have a sketch that would be very helpfull O0
ED
mogogear
« Reply #10 on: October 27, 2010, 06:39:56 am »
Ed
as far as books - back in the steam section there are more than a few books listed at the beginning of the section . There is a resource STICKY where many of us have listed links or suggested must read titles
http://www.rcgroups.com/forums/showthread.php?t=1226384
Good luck on your journey!!
SNOOPDOG32
« Reply #11 on: October 27, 2010, 09:40:15 am »
Thanks for that mogogear will take a look at that  :-))
ED
SNOOPDOG32
« Reply #12 on: October 28, 2010, 01:25:08 pm »
Thanks for all the help so far  :-))
What lubricator would you chaps recomend for the Graham TVR1A engine there seems to be quite a few different designs about
some have a valve attatched !
gondolier88
    • Coniston Regatta
« Reply #13 on: October 28, 2010, 04:44:07 pm »
They are all pretty much a muchness, but the ones with a valve on the inlet allow you to refill under boiler pressure.
Greg
HS93 (RIP)
« Reply #14 on: October 28, 2010, 05:00:36 pm »
have a look on hear they have some nice stuff BUT remember they are in metric but that is no problem as you get the olives and nuts with them so with a bit of sanding you can make them fit in minuets
http://translate.google.co.uk/translate?js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&sl=auto&tl=en&u=http%3A%2F%2Fwww.modellbau-niggel.de%2F&act=url
peter
SNOOPDOG32
« Reply #15 on: October 28, 2010, 08:46:38 pm »
Thanks again for the info  :-)) peter and greg will look at the site still undecided on a hull
anyone know of any different supliers looked at kingston river queen & metcalf solent
want an open launch / work boat style like bernhards style of wonderfull models
not that i could get near his standard
ED
SNOOPDOG32
« Reply #16 on: October 29, 2010, 11:29:19 pm »
HS93 (RIP)
« Reply #17 on: October 30, 2010, 12:10:34 am »
He is good to deal with he is ex Cheddar worker so knows the plants in side out, and a nice bloke.
peter
HS93 (RIP)
« Reply #18 on: October 30, 2010, 12:43:13 pm »
info on the internals of a condenser, hope it helps
peter
SNOOPDOG32
« Reply #19 on: October 30, 2010, 12:46:14 pm »
Thanks again for the replies Peter most usefull  :-))
ED
south steyne
« Reply #20 on: October 30, 2010, 12:59:49 pm »
Hi I think 3/16th exhaust pipe is too small and may choke your engine under full power , just a thought
gondolier88
    • Coniston Regatta
« Reply #21 on: October 30, 2010, 05:30:40 pm »
What size is the steam supply pipe on TVR1's?
Greg
SNOOPDOG32
« Reply #22 on: October 30, 2010, 07:30:48 pm »
Hi Greg think its 4mm has not arrived yet should be here begining of next week  O0
hi John just wanted the diagram for the layout of the condenser will be using 5/32 tube
ED
gondolier88
    • Coniston Regatta
« Reply #23 on: October 30, 2010, 10:28:22 pm »
Hi ED,
Exhaust pipework should really be a larger diameter than the supply- I would stick to 3/16" for the condenser. If your anxious to save space then you could always make the condenser horizontal.
Greg
SNOOPDOG32
« Reply #24 on: October 31, 2010, 01:03:08 am »
Thanks Greg all info greatfully accepted
ED
Pages: [1] 2 3   Go Up
Page created in 0.022 seconds with 21 queries.
