Author Topic: Esc advice  (Read 2279 times)
Lord Bungle
Esc advice
« on: October 28, 2010, 11:49:37 am »
I thought I had better ask advice on this before I spent any money.
I am rebuilding a MFA Spear, its running a Barracuda Motor. nemesis has very kindly informed me that it runs at 1 amp on the bench with 12 volts. And is using an electronize with a 10amp fuse, would I be ok to run mine with MicroViper Marine10 or as there is plenty of room would I be better off with a Mtronik Viper 15 Marine ? any and all good advice welcome.
Bungle
red181
Re: Esc advice
« Reply #1 on: October 29, 2010, 07:12:45 pm »
Hi Bungle, bench running, and what happens in the water, are two different things, and vary according to the volts you are using, the prop size and type, and how good the drive line is. Always try and give yourself some headroom with the esc, the packaging of the motor (or google results) will give you an idea of the suggested max amp draw, and the stall amps, then you can make a judgement on the esc.
I use more than 10 amps on my lights! :}
Lord Bungle
Re: Esc advice
« Reply #2 on: October 30, 2010, 08:41:54 am »
Thanks for your reply, I will be going for a 15 amp unit, with a 10 amp fuse fitted, after being even some very good advice and help :)
Number 6
Re: Esc advice
« Reply #3 on: October 30, 2010, 10:37:47 am »
Don't know about over there but here Micro10 costs same as 15amp one so I'd go for the 15 anyway. Dave.  :-))
Lord Bungle
Re: Esc advice
« Reply #4 on: October 31, 2010, 08:09:42 am »
I ended up going with the viper marine 20 as they didn't have any 15's in stock, running it with a 15 amp fuse   :-)
Page created in 0.844 seconds with 18 queries.
