Author Topic: Balsa wood glue for a sparrow hull - which one is considered best, please?  (Read 4037 times)
steamboatwilly
Used balsa wood cement when I built my aeroplane 50 years ago.
Now about to start the SPARROW yacht which is balsa wood frames, planked with balsa strip.
Would appreciate advice on wether to use balsa cement, pva, or thin cyanoacrylate.
Many thanks.
Will
Jimmy James
Re: Balsa wood glue for a sparrow hull - which one is considered best, please?
« Reply #1 on: November 12, 2010, 07:47:34 pm »
I don't know which is best ---But I have (for the last 20 or so years) been using Thick or Med cyano ---I find it takes slightly longer to grab so can be positioned more accurately and if I need it to grab quickly I give it a squirt of accelerator
Freebooter  :-))
Kings Lynn
Dekan
« Reply #2 on: November 12, 2010, 08:09:48 pm »
I would use Titebond, it an Aliphatic it "grabs" well... lots of model plane builders use it, balsa cement is not used much nowadays. Titebond 111 is the most waterproof version
Deluxe's Aliphatic is also good...
« Reply #3 on: November 12, 2010, 10:05:42 pm »
Definately an aliphatic, after Balsa Cement we used "Resin W" for A/C a PVA, Aliphatics are a waterproof version.
  Regards   Ian
andrewh
« Reply #4 on: November 13, 2010, 03:07:24 am »
Will
Go for balsa cement - waterproof, sands well and gives the nose a nostalgic refresher
I use it and/or any white glue for building in balsa
andrew
« Reply #5 on: November 13, 2010, 11:05:23 am »
If you use Balsa cement don't forget, you'll need full breathing filters and a face mask, otherwise you may fall foul of the "Elfins". You are over 16?????
   Regards   Ian.
« Reply #6 on: November 13, 2010, 03:54:58 pm »
I'm building mine using Titebond III
Planked 1/4 of the hull today, no probs with
the glue.
terryyacht
« Reply #7 on: November 13, 2010, 07:09:49 pm »
I would definatly use PVA glue.
Superglue is good but not as flexible as pva which will also soak into the wood.
Terryyacht
Sailing is always a challenge and every voyage different
Page created in 0.257 seconds with 21 queries.
