Author Topic: Futaba Skysport 4YF 2.4 GHz FHSS  (Read 11903 times)
livesteam
« on: November 17, 2010, 10:08:38 am »
Hello!
I just came across this RC-System from Futaba. It's got a very economical price and as I consider to change to a 2.4ghz system since quite a while, this is interesting. 4 channels should be enough for most of my applications. The only problem: It's not compatible to the Futaba FASST-System, it seems only to run with the (quite expensive...) Futaba FHSS Rx.
Does anyboy know this radio? What are you thinking about it? Maybe Rx from other manufacturer would fit?
Thanks!
Mankster
  • Wheelerdealer
    • RC Model Submarines
Re: Futaba Skysport 4YF 2.4 GHz FHSS
« Reply #1 on: November 17, 2010, 10:41:40 am »
The radio its self is long tried and trested and the package is good value. As you mention additional reveivers will be expensive. There maybe clone RX's soon that may be compatible but wont be CE aproved (as the FASST is patented by Futaba)  and probably not covered by any model insurance you may have.
Lord Bungle
« Reply #2 on: November 17, 2010, 10:57:11 am »
As far as I understand the rx has to match the tx make on 2.4ghz sets, There are plenty of good inexpensive 2.4ghz set out there now, The price of the rx may be something to judge what unit to buy on, as people are more often going to want more rx units than tx units.
RaaArtyGunner
« Reply #3 on: November 17, 2010, 11:49:13 am »
Have two unused 4YF sets albeit they are FM and identical in appearance to the 2.4ghz version.
Am having problems trying to work out how to convert them to 2.4ghz.
The Frsky 2.4ghz Futaba module conversion (on another thread under 2.4ghz conversions) does not specify it as compatable with the 4YF system.
Nor can I find any wiring diagrams.
Really didn't want to bin the FM sets unless absolutely necessary.
Mankster
  • Wheelerdealer
« Reply #4 on: November 17, 2010, 12:08:43 pm »
The FRSkya and Corona Hack modules are compatible with all PPMradios. The Futaba 4YF is one such radio. If there aren't instruction posted online somewhere then you would need to to identify the +ve -Ve and PPM Signal wires on the Futaba PCB yourself.
livesteam
« Reply #5 on: November 17, 2010, 12:20:22 pm »
Well, I have to admit that I don't realy trust all those no-name products... maybe I am wrong  {:-{
RaaArtyGunner
« Reply #6 on: November 17, 2010, 12:27:57 pm »
Mankster,
And there is the glitch, as according to the instructions you need some piece of equipment which is beyond me to identify the connections. :(( :(( :((
Have tried googling for wiring connections but no luck. <:( <:(
Mankster
  • Wheelerdealer
« Reply #7 on: November 17, 2010, 12:37:36 pm »
Does your transmitter have a trainer port?
barriew
« Reply #8 on: November 17, 2010, 01:04:01 pm »
Well, I have both a Spektrum DX5e with 2 AR500 Rxs, and a Giant Cod TX with about 6 Rxs. The latter set up cost considerably less than the former, has analogue trims which I prefer and has been  just as reliable and has at least the same range. ( This means both sets are still working when I have difficulty seeing the model).
Barrie
Lord Bungle
« Reply #9 on: November 17, 2010, 01:05:51 pm »
I am using the Planet t5 and have found no problems with it yet.
RaaArtyGunner
« Reply #10 on: November 17, 2010, 09:16:15 pm »
Hi Mankster,
Instructions say, top left front is trainer switch and on back is Trainer Jack (small rectangular 6 socket).
Under Trainer function it states
"The special trainer chord can be connected to SKYPORT4, FF5, SKYSPORT6, 6X series, 7U series, 8U series ,9C series and PCM1024Z series transmitters."
Mankster
  • Wheelerdealer
« Reply #11 on: November 17, 2010, 11:52:54 pm »
So you must have the newer square trainer port.
Here the pinout diagram http://users.belgacom.net/TX2TX/tx2tx/english/tx2txgb3.htm
by tracing which wires go to which pins on the inside of the trainer port, you now have your +Ve, ground and PPM signal.
RaaArtyGunner
« Reply #12 on: November 18, 2010, 10:26:07 am »
Mankster,
Much appreciated and just to make sure I haven't got it wrong here is a photo of the front and rear.
Mankster
  • Wheelerdealer
« Reply #13 on: November 18, 2010, 11:37:16 am »
Yes thats the Futaba 'square' plug. Your good to go.
BTW '+Ve switched' is the +Ve you want - comes live wihen you switch on the TX.
RaaArtyGunner
« Reply #14 on: November 18, 2010, 12:04:30 pm »
Thank you
 :-)) :-)) :-))    O0 O0 O0
RaaArtyGunner
« Reply #15 on: December 06, 2010, 01:10:33 am »
FrSky bits for the Futaba Skyport 4YF FM see post No. 12.
All is needed is steady hand and powerful glasses to install them after Santa (SWMBO  O0 O0 ) gives them too me O0 O0
Page created in 0.418 seconds with 22 queries.
