Author Topic: Marine glow engine plumbing  (Read 4053 times)
Brookson1
« on: December 16, 2010, 12:10:53 am »
OS 20 Max - What are all the input/output nozzles for? I'm  used to diesel motors. help please. {:-{
Roadrunner
Re: Marine glow engine plumbing
« Reply #1 on: December 16, 2010, 12:15:34 am »
im assuming your on about the nozzles on the cylinder head ? if so there the water cooling intake out takes
martno1fan
« Reply #2 on: December 16, 2010, 10:52:00 am »
Yes theyre water inlet and outlets,go in at the bottom and out at the top fitting this makes sure you have no air trapped in the cooling cap so allows the cap to fully fill with water  ok2 ok2.
Brookson1
« Reply #3 on: December 21, 2010, 12:31:34 am »
Thanks for your help, but, the problems I have are with the crankcase & silencer connections.
Best
Dave  (Preston)
brianB6
« Reply #4 on: December 21, 2010, 02:47:48 am »
can you post a picture?
There should not be much difference between glow and diesel motors
Roadrunner
« Reply #6 on: December 21, 2010, 10:35:59 am »
What problems with the crank case and silencer are you having? A little more detail on your issue would be handy to suggest a fix.
Page created in 0.017 seconds with 21 queries.
