Author Topic: planking size  (Read 3832 times)
toptugger
planking size
« on: December 24, 2010, 06:35:35 am »
i'm going to be building a 1:24 F/V from scratch, but i'm not sure what wood to use for the hull planking and what size and thickness. The hull will be painted so i'm not worried about using posh wood to get a finish, just the best for planking.
could someone give me some advice please
tugmad
Re: planking size
« Reply #1 on: December 24, 2010, 08:06:04 am »
Hello toptugger   I build 1/24th scale tugs and I use Limewood planking and find that it is a really easy to use wood that does not split and is really flexible. so much in fact that there is no need for bow and stern blocks as the wood curves and twists very easily, id the curve is too much for the wood when dry i just soak it in hot water for a few minutes then pin into place, so far I have had no problems at all even around the complex curves of a tug stern. the sizes that I use are 10 or 12mm by 3mm thick.
Geo.
tugmad
Re: planking size
« Reply #2 on: December 24, 2010, 08:10:35 am »
 A couple more pics showing the curve that is possible with lime.
Roadrunner
Re: planking size
« Reply #3 on: December 24, 2010, 09:07:07 am »
lime is a good all round planking material for planking hull's and decks if you decided to stain and polish it it works nicely that way too with a very fine grain, easy to shape bend etc not expencive either.
6mm strips should be appropriate for your need.
Availible here.
http://www.alwayshobbies.com/Boats/Materials/Planking-and-Mouldings/Planking-Stripwood.ice
triumphjon
Re: planking size
« Reply #4 on: December 24, 2010, 04:00:09 pm »
id second the lime for the planking , as like said earlier its not hard to work with .
Bryan Young
Re: planking size
« Reply #5 on: December 24, 2010, 06:44:24 pm »
I'll agree with everything thats been said....but isn't lime a bit on the pricey side? Although, horses for courses perhaps? BY.
Notes from a simple seaman
Roadrunner
Re: planking size
« Reply #6 on: December 24, 2010, 06:52:44 pm »
£1.95 per 5m not sure if that's expensive, i though it was quite reasonable for pre cut strips.
I think maybe a sheet which needs reducing to planks may be on the pricey side as always all subject to your budget as to what's affordable i guess.
John W E
  • I see no ships !!
Re: planking size
« Reply #7 on: December 24, 2010, 08:35:41 pm »
Hi there Toptugger, the tug you are building you say 1:24 scale - so hazard a guess - could it be somewhere in the region of between 30 & 40 inches long?    Obviously, the size of model can dictate the size of planks and the material used - also, the shape of the hull can dictate the size of the planks and the building method used.  e.g. I have seen a fairly large hull (over 40 inches long) planked using balsa wood as the planking material.  But, this is then sheathed on both the inside & outside with fibre glass giving the hull its strength and durability - so this is one possibility for you.
There are many materials which may be used to plank a hull - one which has been mentioned already and there are also obechi planks which are slightly harder than balsa wood.   There is also mahogany which may be used.    There is cedar wood too, if you have a look in the master class build - a guy has produced a hull using cedar wood.  Other materials as one member has suggested in the past was wood used in venetian blinds - but you do need the facility to cut your own planks.
Just some thought and also there are a good few companies about who supply various planking materials - Jotika supply also - but best speak to them over the phone.  Mantura Models do this, and Cornwall Model boats do too.....
Hope this is of some help
aye
john e
bluebird
Knowledge begins with respect
cosmic
Re: planking size
« Reply #8 on: December 30, 2010, 05:25:35 pm »
Sycamore, 2X5mm on a 920mm hull.
I like the sycamore for its very fine grain, and its "bendiness". Although that lime looks very nice.
http://www.mansfieldwoods.net/models/100_0328.jpg
