Author Topic: My First Boat.  (Read 1924 times)
robertall
My First Boat.
« on: December 26, 2010, 10:13:43 pm »
I am currently starting a project to make my own boat - well i kind of cheated. I found a 2nd hand hull with a broken rudder and a small electric motor in, which i am going to modify and make into a nice boat. I think the electrics are shot, they don't look very good. I am wondering if anybody could advice in getting a small motor. I am bidding on a Merco 49 on eBay at the moment which was originally fitted in a model boat which caught fire originally. The seller says it is running with 100% compression.
I am totally new, and i only spur of the moment i decided to buy the boat. it is approximately 1 1/2ft wide and around 3-3 1/2 ft long. The electric motor originally fitted was smaller than a mobile phone (it is turning over but i guess the motor will be similar to a scaletrix car motor, and it appears to have "no compression" and turns over extremely easy - too easy).
I don't have any pictures of the item at the moment as i am currently away from home, but when i get back, i will put some pictures. It is a bit of the dog, it is going to need a spray up.
There is one other thing i could do. I have got an old 33cc JAP 2stroke engine from the 1940's or 1950's which i could, which produces around 0.5 bhp. It is a bit heavy, and it is a very rare item and it would be a disaster if it was sink. It weights 3-4 kg instead of under 1kg which the merco has.
Please advice me,
Rob
nick_75au
Re: My First Boat.
« Reply #1 on: December 26, 2010, 10:47:18 pm »
Hi Rob
Electric motor may be fine, some motors don't have  cogging ,which is what i think is what your trying to describe. Just connect a 6 volt or so battery to it to see if it works.
Im a little confused, is it a different boat for the Jap motor, the boat would have to be bigger than 3 1/2 foot for that motor.
Nick
robertall
Re: My First Boat.
« Reply #2 on: December 26, 2010, 10:59:20 pm »
I did think about the 33cc engine, but i guessed it would be a bit too big. I will try that motor next weekend and see it if it a worker or not. It just didn't appear right so i didn't bother to check. The prop appears to be good but it seems too small. It is probably in proportion to the boat.
Page created in 0.428 seconds with 19 queries.
