Author Topic: Formula for cc versus size of the boat.  (Read 3965 times)
KBIO
« on: March 09, 2011, 04:28:18 pm »
Hello!
I have been through the forum trying to find anything about the way to calculate the cc's needed versus the boat's size.
There is a lot to see, but I didn't find anything concerning this point.
If I remember, I used  : cc = Length x width x heigth (@water line) x 2/3 for a tug.
I guess that there is better formula , and I would appreciate your help on this matter.
Thank a lot !
Cheers.
gondolier88
  • www.coniston-regatta.co.uk
    • Coniston Regatta
Re: Formula for cc versus size of the boat.
« Reply #1 on: March 09, 2011, 10:04:34 pm »
Hi KBIO,
Are you talking about the size of the engine or the volume of the hull?
Greg
KBIO
« Reply #2 on: March 10, 2011, 07:15:49 am »
Hello Gondolier!
I am taking of the size of the engine.
Question: what size of steam engine(cc)  is requested for a launch (or a Tug) of 4 ft long.
i guesss that the power of the engine changes according to the weight and shape of the hull!
Thank you & cheers! :-)
« Reply #3 on: March 10, 2011, 07:57:18 am »
KIBO....I am sure you would be familiar with the references provided on the JMC web site  O0 ...........Derek
Les conseils techniques de JMC
 cylindrée moteur
 poids du bateau
1 centimètre cube
 jusqu'à 4 Kg
2 CC.
 de 5 Kg à 6 Kg
3 CC.
 de 6 Kg  à 7 Kg
5 CC.
 jusqu'à 15 Kg
8,5 CC.
 de 14 Kg à 20 Kg
10 CC.
 de 16 Kg à 20 Kg
15 CC.
 de 18 Kg à 24 Kg
3 cylindres 7,5 CC.
 bateau de 1m40
3 cyl. 4,5 CC.
 de 6 Kg à 8 Kg
3 cyl. 1,5 CC
 de 3 à 4 Kg
« Reply #4 on: March 10, 2011, 08:05:26 am »
Or in English.
KIBO....I am sure you would be familiar with the references provided on the JMC web site  OK ...........Derek
Technical advice to JMC
 cylinder engine
 Boat weight
1 cc
 Up to 4 Kg
2 CC.
 the 5 Kg to 6 kg
3 CC.
 the 6 kg to 7 Kg
5 CC.
 up to 15 Kg
8,5 CC.
 the 14 kg up to 20 kg
10 CC.
 the 16 kg up to 20 kg
15 CC.
 the 18 kg up to 24 kg
3 cylinders 7.5 CC.
 boat 1m40
3 cyl. 4,5 CC.
 the 6 to 8 Kg Kg
3 cyl. 1,5 CC
 the 3 to 4 Kg
KBIO
« Reply #5 on: March 10, 2011, 08:19:08 pm »
Good evening!
Yes I know, those figures that  JMC (and some others) are using.
I just wanted to know if , you guys around the world have another way to find out.
I found some litérature describing another way to calculate engine size versus Boat's weight.
I need to translate in English and I shall submit it for you to tell me what you think.
Thanks a lot anyway . I'll be back soon! ok2
Cheers!
KBIO
« Reply #6 on: March 11, 2011, 07:40:31 am »
Hello!
I found this formula on an old Steam Model Book, and I wonder if it is right or a bit pessimistic as some  4 ft models are moved w/ 3cc. (in a quiet pond, no wind).
Formula is :    Length x Width x Heigth
                                    a
Length is over all length
Width is over all width
Height is from the water line daown to queal.
a is a coefficient which varies depending of the country.
England    a    = 3000 pour L    =   75 cm            Holland      a    = 4350 pour L=      75 cm
                    = 2800                =   90                                         = 4000            =      90
                    = 2700                = 100                                         = 3900            =    100
                    = 2500                = 120                                         = 3600            =    120
                    = 2300                = 140                                         = 3300            =    140
                    = 2100                = 150                                         = 3000            =    150
In France, we use the Dutch formula and we add 20%.
Ex , for a French hull:  L= 100 cm  B= 20 cm P = 10 cm ===>
                                                       100 x 20 x 10  = 5.1 cc + 20% = 6.1 cc
                                                               3900
The difference of these coeficients is explaned by the shape of the hulls. Dutch hull would be a bit wider than British ones.
Conclusion : I would apply Dutch formula for a Tug , British one for a launch, and French one for a classic
What do you think??
Thanks for your helpl! ok2
Page created in 0.354 seconds with 22 queries.
