Hi All,
I don’t know if this idea is of any use to any body, but here goes.
My problem was that the inner bronze bearings on the prop shafts on my RTTL were getting very hot, (it didn’t matter about the outer ones as they are in the water) so I decided to change them for ball races. As the shafts were already in the boat I needed to retro-fit the bearings without damaging the hull. Being a poor pensioner (sob) cost was important!
I purchased some 4mm ID / 9mm OD bearings from eBay at 99p each and then needed an adapter to match the bearing to the prop shaft. While playing golf one day I realised that a steel shafted club is tapered in a series of steps and could possibly be made to fit.(Pic 1).
I have changed from steel shafted clubs to graphite shafts and had several redundant (cheap) clubs so I measured the club shaft and cut it at the correct size. (Pic 2).
Having cleaned and squared up the cut edges I then pressed the ball race into the large end of the adapter using a vice. (Pic 3).
I knocked out the old bronze bush and pushed the small end of the adapter onto the shaft with a little smear of Araldite to secure it, added an oiler from Cornwall Model Boats and Bob’s yer mother’s brother! (Pic 4).
(The shaft in Pic 4 is just for illustration purposes only).
I expect this has been done before but it just proves that golf is not totally useless….
Dave.
