Author Topic: Anyone built a SEEKADETT?  (Read 12835 times)
livesteam
« on: March 27, 2011, 09:18:33 am »
Hello!
The website of MHB says that they will stop the production of Topaz and Seekadett. It's a kit that's in my mind since a long time (as I live at the lake of Zurich and know escher Wyss quite well) and now this would be the last chance (although I do not have the time for building another model just know...).
Who has bulit the kit and woulde tell the experiences with it?
Thanks a lot!
Kaspar
Engineman
  • Full Steam Ahead!
Re: Anyone built a SEEKADETT?
« Reply #1 on: March 27, 2011, 03:16:54 pm »
Dear LIVESTEAM,
You can find a very comprehensive story of building procedure for DER SEKADETT steam launch from MHB kit on modelismonaval.com steam forum.
Hope this will help.
Roman
livesteam
« Reply #2 on: March 27, 2011, 03:28:11 pm »
Thanks ENGINEMAN! Unfortunately I don't understand a word of Spanish, but still it's a very useful story of building just because of the pics! A great build..!  :-))
HS93 (RIP)
  • I cannot spell , tough
« Reply #3 on: March 27, 2011, 04:15:05 pm »
have you got a link as I am having difficulty finding it.
thanks
Peter
Engineman
  • Full Steam Ahead!
« Reply #4 on: March 27, 2011, 05:10:54 pm »
You're welcome Kaspar!
Here is the direct link Peter - http://www.modelismonaval.com/foro/viewtopic.php?f=13&t=2631
HS93 (RIP)
« Reply #5 on: March 27, 2011, 07:57:32 pm »
thank you for that , I am about to build one now.
peter
Engineman
  • Full Steam Ahead!
« Reply #6 on: March 27, 2011, 09:38:57 pm »
Looking forward for another interesting build story. This time in English  :-).
mogogear
« Reply #7 on: March 28, 2011, 04:33:24 am »
peter
Peter-- you are living my dream!!! I will be following you
JJS
« Reply #8 on: March 28, 2011, 12:24:35 pm »
Hi, I am presently building Der Seekadett. I bought the model last year. Did the steam engine last year and just fitted it for the first time in the hull. I also use the photos from the spanish website. It gives a good help as the instructions are not that extensive with information. You can use the English translator at the site.
I will make a picture of mine and will put it on here
JJS
« Reply #9 on: March 28, 2011, 01:37:06 pm »
We look forward to it  :-)) :-)) :-))
JJS
« Reply #10 on: March 28, 2011, 02:50:25 pm »
Engineman
  • Full Steam Ahead!
« Reply #11 on: March 29, 2011, 07:35:04 pm »
Pretty much hope to see the further updates for this very interesting build !
Regards, Roman
JJS
« Reply #12 on: April 17, 2011, 02:42:49 pm »
Inside finished and painted in primer
jjs
mogogear
« Reply #13 on: April 17, 2011, 04:55:29 pm »
The best bow that there is on a model boat!! I have always lusted for one from afar :-))
JJS
« Reply #14 on: April 22, 2011, 10:16:40 am »
Steam plant for the Seekadett
JJS
JJS
« Reply #15 on: April 22, 2011, 10:39:57 am »
Test run Seekadett Steam plant:
http://www.youtube.com/watch?v=JdvCZV1g_iE
JJS
kno3
« Reply #16 on: April 22, 2011, 11:46:45 am »
Very nice! How much water does the boiler hold?
JJS
« Reply #17 on: April 22, 2011, 12:03:23 pm »
Thanks,
The volume of the boiler is 1,2 L; usable capacity 1 L. The unit is flue boiler with cross tubes, internal vertical flue and return tube, made by MH&B
JJS
kno3
« Reply #18 on: April 22, 2011, 12:40:00 pm »
Oh quite a big boiler, I guess you get a long running time with it.
« Reply #19 on: April 22, 2011, 01:20:51 pm »
Hullo JJS....that is a very good looking & interesting package.... :-))
the engine...is it from Anton?
the lubricator is from Winfried Niggle
the gas regulator & gas auto shut off ...are they from JMC?
who is the manufacture of the gas tank &...assumed similar low profile de-oiler condenser?.........
& very tidy [true+horizontal+vertical] tube work displayed too O0 .......Derek  :-)
JJS
« Reply #20 on: April 22, 2011, 01:55:29 pm »
Hi Derek,
The engine is indeed Anton, gastank and condensor are MH&B. It is the steam plant package which goes with the Seekadett model. I added flyweel, the Niggel oiler and Anton gas regulator and steam whistle . My only fear is that the plant needs on a "diet"  :-) when at sea, as the Seekadett hull is a light displacement hull, and the additional weight i have put into the steam plant could put it to deep on water line.
JJS
JJS
« Reply #21 on: April 22, 2011, 02:11:23 pm »
According to running instructions it should give 35 minutes of running time, but i am not sure if this is bound to the water capacity or gas capacity. I did not yet do a long running test with the plant. My feeling is gas capacity is the limiting factor, but as i have fitted the gas regulator i suppose i will get some longer running times.
Here the Anton regulator / pressure drop shut of valve
JJS
« Reply #22 on: April 22, 2011, 02:37:46 pm »
JJS..... I have a V71 gas regulator from Anton ...however it yet to be commissioned  <*< ..please keep us posted with your Seekadett photographs.........
With your Anton V7? gas control system........& hence gas saving  :-)) .....I suggest that boiler water will be the limiting factor.......... Derek
KBIO
« Reply #23 on: April 22, 2011, 05:16:49 pm »
Hello JJS :-)
I would agree with Derek, according to the size of your gas tank: you'll run out of water before gas. So be careful , and watch your water  level to find out what is the safe time of sailing.
Your propeller is very nice and , it does not need a lot of RPM to move the Seekadet, so I wouldn't be surprised that by running smooth you get 45 min sailing & even more. above all with the regulator and no more than 2 bars pressure setting.
Let us know, it will be useful datas !
Regards. ok2
JJS
« Reply #24 on: April 24, 2011, 11:17:06 pm »
Did a duration running test today with full gaz tank and boiler. The lever of the anton coupe gaz V 70 arms nicely at 40 psi, took 15 minutes to get to 40 psi. I have the impression the gaz regulater V 72 does not really regulate, but give only a very low gaz flow. gives only a 15 to 20 psi pressure on running. After 90 minutes i run out of gaz it only consumed half of the boiler water, i have run the engine  for over an hour, but on low speed because i could not get pressure above 20 psi during runs. Limited factor seemed to be the condensor tank as it was ejecting water during running. The V70/V72 are nice pieces of engineering but i have a doubt if they work properly. Any one experience with these?  I am going to make a run without these installed but have first to make a bypass gaz line for it. Keep you posted on next duration run.
JJS
Page created in 0.252 seconds with 22 queries.
