Author Topic: Dive-in at Lido. First Brockwell Dive-in of the year 27th March 2011  (Read 11815 times)
Patrick Henry
Re: Dive-in at Lido. First Brockwell Dive-in of the year 27th March 2011
« Reply #25 on: April 01, 2011, 03:43:46 pm »
Cheeky....give us a kiss.   :D
MikeW
« Reply #26 on: April 02, 2011, 10:17:14 am »
Opps basic mistake, not good with forums! I will repost in a new thread.  :embarrassed:
gyronuts
« Reply #27 on: April 02, 2011, 08:30:59 pm »
mankster....thought that conning tower in the background of the last photo was huge..then realised it was a rubbish bin!!!
Bill
silent running556
« Reply #28 on: April 03, 2011, 01:32:59 am »
Nice details on that u boat too, the rivets and the rusting looks very good.
silent running556
« Reply #29 on: April 03, 2011, 01:56:26 am »
That reminds me, you know the half tonne robbe 6v 5ah batteries recommended for the u 47, how do you charge them up? Thanks.
Subculture
    • Dive-in to Model submarines
« Reply #30 on: April 03, 2011, 08:43:09 am »
Bill
LOL, I hadn't spotted that, but I see what you mean now. The coke tin perched on top almost looks like a flag too!
thegrimreaper
« Reply #31 on: April 04, 2011, 10:34:41 am »
As the Robbe batteries are very expensive Robbe probably recommend you use there Robbe battery charger which is probanly very expensive now if only Carling made battery chargers  :-))
In my U47 I ditched the Robbe batteries and went with 12 vols 3 amp hour batteries thes also help with the ballesting of the sub making dynamic diving easier to attain because the U47 now sits lower in the water at deck awash
Regards Mark
Subculture
« Reply #32 on: April 04, 2011, 11:18:54 am »
I use an icharger 106B, which is complete overkill for lead acid battries, but I'm not sure if there is a battery that has been invented that this charger cannot deal with. It does the lot, and is a fantastic piece of kit, and stunning value for money IMO.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6792
thegrimreaper
« Reply #33 on: April 04, 2011, 02:39:36 pm »
Andy is this charger suitable for lead acid just looked at the specs and lead acid aint mentioned or am I barking up the wrong tree here and the Robbe batteries arn`t lead acid ?
Spec.
Input voltage range : 10.0 – 18.0VDC
Charge current range : 0.05 – 10.0A
Discharge current range : 0.05 – 7.0A
Maximum charge power capacity : 250W @ input voltage > 13.5V
Maximum discharge power capacity : 20W
Maximum extern discharge power capacity : 170W @ 20V/7A
Current drain for balancing : <300mA
Balance accuracy : <10mV
Lithium (LiPo/LiIo/LiFe) battery cell count : 1 – 6 series
NiCd/NiMH battery cell count : 1 – 17 series
Pb battery cell count : 1 – 12 series (2 – 24V)
Battery setup memories : 10
Intelligent temperature control : Yes
PC Connect : USB port
Weight : 350g
Dimensions (L X W X D) : 134X83X25mm
Regards Mark
Subculture
« Reply #34 on: April 04, 2011, 03:14:51 pm »
It does say that- Pb is lead acid (Pb is the chemical symbol for lead).
The Robbe boats I've seen use lead acid batteries, unless the owner has deviated from the original design.
thegrimreaper
« Reply #35 on: April 04, 2011, 03:17:31 pm »
aahh right thanks for that Andy live and learn science teacher always said I was a thicko
Regards Mark
Subculture
« Reply #36 on: April 04, 2011, 03:26:11 pm »
Derived from plumbonium, which I think is the latin word for lead, which the Romans used extensively for their pipework, and is most likely where plumbers got their name from. If only they charged Roman rates!
silent running556
« Reply #37 on: April 06, 2011, 12:29:31 am »
Yep deffo lead acid,ordered a charger off of Mainly Models for £13 odd, the Robbe one was £35.  I think i'm turning the corner a bit on the soldering side of things at least, hopefully anyway.
I think the charger is via JP or Ripmax i think. Very similar to the one i've got for the receiver/transmitter batteries.
Page created in 0.261 seconds with 22 queries.
