Hello,
I'm a bit stuck trying to configure the (twin) rudders on my RTR Severn conversion. The twin part is not a problem here.
I generally understand leverage/throw but seem to be unable to apply this to the setup: It appears that movement is always greater in one direction. I've tried adjusting the arm on the servo (putting it off centre), or the arm length etc but don't seem to be abled to get a smooth setup.
I've attached a pic of the rudder arms and where the servo is located (could be moved, want to keep it central though).
Also a pic of what, to me, should work. The servo arm in neutral is parallell to the rudder arms (which are more parallell than shown) and the link rod is pretty much 90 degrees to the arms. This setup still seems to favour one side more than the other - unless this is an illusion, or the small inaccuracies cause it?
Are there any fundamental principles which apply to linkage geometry?
Jonathan
PS, Stan: I can't do the setup you sketched as my rudder arms aren't at 90 degrees
