Author Topic: alternator/dynamo  (Read 2770 times)
manx venture
alternator/dynamo
« on: April 25, 2011, 03:36:57 pm »
hi,  is there such things as alternators/dynamos for models?  same idea as real boat engine, so when motor turns it drives a pulley on the shaft and round an alternator to charge the battery as you go along, has this been done and dos it work,
cheers
Darren
Re: alternator/dynamo
« Reply #1 on: April 25, 2011, 03:42:16 pm »
If you've got an electric boat and it worked then you would have invented perpetual motion! In fact any power generated by a dynamo would put an extra load on the motor much larger than the power generated by the dynamo and simply run the battery down more quickly.
If you have a i/c boat (as are full size vessels) you don't need a battery anyway!
« Reply #2 on: April 25, 2011, 05:02:53 pm »
Mamod used to do a belt driven dynamo for some of the static models
I seem to remember a pump house with a street light alongside it
I bet there is a steam launch out there somewhere with dynamo driven lighting!
funtimefrankie
« Reply #3 on: April 25, 2011, 05:14:03 pm »
An electric motor should act as a dynamo if driven.
Off topic interesting point.....Years ago I tied to make a generator with a lawn mower engine and a car altenator, it just stalled the engine... not enough power, I had to use a dynamo in the end.
« Reply #4 on: April 25, 2011, 05:24:10 pm »
http://www.mamod.co.uk/product_view_details.asp?pids=16&pr=1380%20Showmans%20Engine
They still do!
john s 2
« Reply #5 on: April 26, 2011, 09:04:36 am »
A trawl of the Steam section on ebay should result in finding a suitable dynamo.Bing along with mamod and
Wilesco Make them. As said often used on scale Showmans Engines For the lights. John.
Page created in 0.016 seconds with 21 queries.
