Author Topic: So I ordered my 1st boat and loads parts hit card hard  (Read 2956 times)
Boatbuilder2011
« on: May 07, 2011, 04:21:07 pm »
Hi I have ordered my new boat the modelslipways Teskoa I'm going to be installing a bow thruster in it also going to be fitting a water cannon just for fun but I was wondering if any one can explain how u fit the motor and everything for the water cannon plus with the bow thruster what do I use a separate speed controller from the main drive unit? If I wanted to motor rize radar how easy is this? Hopefully u guys can explain or have a link I did try a search
Roadrunner
Re: So I ordered my 1st boat and loads parts hit card hard
« Reply #2 on: May 07, 2011, 08:09:41 pm »
Just use a car windscreen washer pump to pump water, you can set this with a micro switch to on and off rather then use another esc for it, bow thruster you can use the same or you can purchace a pre-build one, i wrote a few post's on this the other day...
https://www.modelboatmayhem.co.uk/forum/index.php?topic=30136.0
Check the thread.  :-))
''So I ordered my 1st boat and loads parts hit card hard'' Welcome to model building, what did you expect it to be a cheap hobby?
« Reply #3 on: May 07, 2011, 10:05:58 pm »
I'll go with Ned on this, you need to speak to Dave at ACTion he's the expert.
http://www.action-electronics.co.uk/pdfs/Slipway%20Dutch%20Courage.pdf
Page created in 0.014 seconds with 20 queries.
