Author Topic: Best adhesive for deck planking  (Read 12632 times)
pettyofficernick
« on: May 27, 2011, 12:48:47 am »
Good evening gentlemen, I have started to plank the deck of my Victoria steam launch. What glue is best, cyano or aliphatic? I have tried cyano, but have abandoned it on the grounds that I have stuck myself to the job, stuck the job to myself, got planks stuck to the bench, the dog, the parrot me (again) I just don't get on with the stuff. I have got some Superphatic, a bottle of aliphatic and some 5 min epoxy. I humbly appeal to the great and the wise for guidance, before I go and buy a sheet of Fablon ( only joking) which one will have the best waterproofing qualities?
Many thanks
Nick >>:-(
Re: Best adhesive for deck planking
« Reply #1 on: May 27, 2011, 03:04:28 am »
Nick - a few questions..... {:-{
1. are you using wooden planks onto a full wooden deck?...
2. will you varnish/polyurethane/wax the final planked surface?....
If the answer is YES to both.......plain white PVA glue is fine....you van also use a few drops of superglue to act as instant tacks whilst the PVA dries  :-)) ....Derek
MichaelK
« Reply #2 on: May 27, 2011, 04:50:12 am »
I use waterproof PVA. If you leave it for a minute or two before actually sticking the planking down, it gets quite tacky and dries faster.
Mick
triumphjon
« Reply #3 on: May 27, 2011, 08:25:50 am »
ive been using cyno for mine , it only needs a couple of spots , then hold well away from where the glue is !
Stan
« Reply #4 on: May 27, 2011, 11:43:10 am »
Hi Guys.Spoken to Petty officer should be alright with a good p v a glue. Sticking 6mm wide mahogany planks on to a ply deck.
Stan
nhp651
« Reply #5 on: May 27, 2011, 07:06:55 pm »
i tend to use an Alyphatic quick grab resin.it's waterproof and very strong.
i also colour it with matt black enamel paint in small quantities and when set, it simulates the caulking between the planks
Matt.H
« Reply #6 on: June 19, 2011, 10:34:17 pm »
Hi guys sorry to but in,
on the first answer/questionif u were just planking not onto a dec but over the bulkheads what is the best glue for that.
many thanks matt  :-))
« Reply #7 on: June 19, 2011, 10:43:48 pm »
on the first answer/questionif u were just planking not onto a deck but over the bulkheads what is the best glue for that.
Planking is usually applied to a sheet sub deck. Otherwise there is  a much greater likelihood of leaks. Sub decks can be of very thin ply so should not pose a problem. No point in doing things the hard way!
pettyofficernick
« Reply #8 on: June 19, 2011, 11:34:34 pm »
Evening Gents, well, the planking exercise is all but over, a few tatty bits around the edges, but I think I will get away with it, and I am reasonably satisfied with my efforts. I certainly don't want to strip it all off and start again! I used aliphatic pva from Deluxe Materials in the end, good stuff, dries nice and quickly,but still gives time for adjustment and cleans off with a damp cloth (before it sets). in an attempt to be 'arty' I put 2 runs of 1/2 mm maple I had left over from a Nelsons Navy kit between the planks, doesn't show up to well in the photos, but it is there, about 3/4 inches either side of the centre line. Heres a few phots of my efforts for your comments. Thanks for all the advice,
Nick. :-)) :-)) :-))
MichaelK
« Reply #9 on: June 19, 2011, 11:54:22 pm »
Looks very smart.
Well done. :-))
Mick
Matt.H
« Reply #10 on: June 20, 2011, 09:54:22 pm »
That looks great :-)) what i ment by planking is on the hull planking,
many thanks matt.
MichaelK
« Reply #11 on: June 21, 2011, 06:41:55 am »
Hi Matt
I used West System epoxy
Mick
John W E
  • I see no ships !!
« Reply #12 on: June 21, 2011, 09:29:01 am »
Hi ya there Matt.H
If you are planking a hull then standard PVA glue will do the job - such as EVOSTIK weatherproof job - or and aliphatic glue would do even better.
Have a look at Masterclass build either the Cervia tug or the Spashett - majority of the hulls in the masterclass were planked using standard PVA.
Only use the Ausies West System if you have a canny deep pocket as in MikeK's :-) cos he must be loaded :-)
aye
john
Knowledge begins with respect
kiwi
« Reply #13 on: June 21, 2011, 10:02:13 am »
The WEST SYSTEM was developed and marketed in the USA, long before it was available in Australia and NZ
kiwi
Matt.H
« Reply #14 on: June 21, 2011, 07:15:09 pm »
Thanks guys thats helped a bunch with my latest project. :-))
