Author Topic: HDML  (Read 13624 times)
LarryW
HDML
« on: June 10, 2011, 05:05:00 pm »
HI  LARRY HERE, just got a copy HDML free plan and a hull of a free plan MODEL BOATS ,
 but need help what goes where , the link on model boats web page is a poor pdf  unreadable,also have model boats mag with a
  build guide to not a info for beginner,  is any body else building this model ifso can you help......LARRY....
mikearace
Re: HDML
« Reply #1 on: June 10, 2011, 07:18:21 pm »
Larry
Have you tried Chris at HSL?
http://www.hslmouldings.co.uk/
He has all the fittings if you need them but he is a walking library on helpful things on Coastal stuff.  I would be my last brass farthing he will have a ciopy of this for you to acquire.
LarryW
Re: HDML
« Reply #2 on: June 12, 2011, 02:08:40 pm »
HI ,thank you for replies .,  struggling with wheelhouse build slight errors with drawing spent a good 6 hrs on templates in card
 pattens ,would be nice if a front elevation detail could  have bin added to drawing , and the wheelhouse out would be a bit more ' detailed , i suppose regulars builders find the drawing easy , so don't have a pop at the beginners ,who muddle through
 any way back to build i have got this far see pictures,.....
    hope to get a bit feed back from some of more clever builders i am not frightend of criticism,
 as long its usfull, wich so far on mayum as been first class,
   on my drawing there is a slight error where bridge conects to wheelhouse , so will do a little bodging to get round it,
LARRY....
mikearace
Re: HDML
« Reply #3 on: June 12, 2011, 02:13:39 pm »
Doesnt look bad at all.  Paint and filler hides a multitude of sins so I wouldnt worry.
How are your for fittings?  Have you tried Chris at HSL?  I have a couple of Coastal fittings surplus to requirements if they are of use?
LarryW
Re: HDML
« Reply #4 on: June 12, 2011, 02:40:36 pm »
HI MILKRACE, just put the phone on criss what a nice guy , may have a vac form bridge area for sale,
   only do fixtures and fittings now , the kit side is on the back burner now, but still prepared to help,
   i have to build a second deck structure for my lad who is a cheque book ,modeler
 what bits do you have ? the would interested........ LARRY.....
mikearace
Re: HDML
« Reply #5 on: June 12, 2011, 03:23:20 pm »
I have a spare carley float and a few vents that were left over from an MTB build and although I have another MTB build to do I dont need all the vents I have.  I will have a check later and send you a pm.
Chris is certainly very helpful and friendly.
Re: HDML
« Reply #6 on: June 12, 2011, 05:16:55 pm »
Larry,
These vessels changed so much during their working life that almost any configuration could be correct.
In the med several had the captured German weapons fitted and mostly being harbour based and not a high priority they tended to get what was left after warship (Destroyers etc) refits/upgrades.
Re: HDML
« Reply #7 on: June 12, 2011, 07:07:40 pm »
hi ya Larry
Check your emails cos I have just sent you (hopefully) the original article from 1984 on the build for the HDML - if you dont receive it, let me know :-)
By the photographs you have put on, you havent done a bad job of the build so far - rather good I would say!
I wouldnt worry too much about fixtures and fittings (purchasing) as they are pretty straight forward to make from strips of balsa wood and Plasticard, well within your capabilities I am sure.
aye
john
LarryW
Re: HDML
« Reply #8 on: June 13, 2011, 09:52:43 am »
HI JOHN, thank you very much for your input and jgs much clearer than model boats ones , which i must say as ex semi pro
 photographer are pretty poor yours are much sharper ,  :-))   also that was nice complement about my build,
   one day i hope to get better each build still on a leaning curve , only been boat building 18 months ,
    i follow your build blogs on mayhem, you are very good and informative, more content than model mags,
       thank you again   LARRY.....
LarryW
Re: HDML
« Reply #9 on: June 17, 2011, 04:04:28 pm »
 HI , bit more done , ammo boxes , and cowl bins and gun deck Matt,  also rebuilt wheel house and bridge ,and coffin deck to
suit
 better build there where a few drawing mistakes, now lo0king for a better deck plan, A4 copy Will do, can any body help,
   been on HTML site but old photos a bit grainy,  all so in black and white so looking at , its going to be gray and gray....LARRY...
LarryW
Re: HDML
« Reply #10 on: June 22, 2011, 10:55:24 am »
 HELLO ALL,   still making deck clutter , and fitted ply sub deck yet to trim hull to ,suit
   looking for cheap source of prop shafts , to carry on, next move will be the gun construction, have bits to start,
   enjoying build so far , hope to sell a couple of old models to finance this model ,
    monies tight on a pension,  thats why i scratch build,
    CHEERS LARRY.......
LarryW
Re: HDML
« Reply #11 on: June 22, 2011, 09:14:53 pm »
 HI ALL, had a go builing a deck gun to day , this is the result, i think when painted , it will fit the bill.....LARRY......
mikearace
Re: HDML
« Reply #12 on: June 22, 2011, 09:18:30 pm »
A fine job larry.
Re: HDML
« Reply #13 on: June 22, 2011, 09:47:59 pm »
Larry,
For propshafts try MMB, mark is a member on here : http://www.marksmodelbits.com/
pugwash
Re: HDML
« Reply #14 on: June 22, 2011, 11:21:21 pm »
It's coming on very well Larry
Geoff
LarryW
Re: HDML
« Reply #15 on: June 24, 2011, 05:34:45 pm »
HI ALL; more armory completed,  couple of mg"s and  main gun painted pleased with result, and they cost pennies,
     looking for another gun to go on for deck can you help with what to model ,,?......LARRY......
LarryW
Re: HDML
« Reply #16 on: July 07, 2011, 08:24:15 pm »
HI LARRY  of to Weymouth sunday be looking for a pair motors to suit HDML any suggestions  LARRY
LarryW
Re: HDML
« Reply #17 on: July 16, 2011, 03:53:28 pm »
HI ALL  quick up date, went to Weymouth Sunday enjoyable day  ,ordered to prop shafts from mobile marine as drawing given ,
    custom made £10 EACH   money paid delivered Thursday morning , first class product and service plus i must say post free .
    what first  class company this is will use them again  good old fashioned service and they no what selling again well done  :-))
  no looking at motors , grupner  600 in mind what you think ?..... and also where stanchions round or flat type ?  LARRY...
Re: HDML
« Reply #18 on: July 16, 2011, 03:58:14 pm »
Larry,
The original HDML's had a top speed of 7 knots.
But I have to admit in mine she is overpowered and does look good (in my opinion) running nuch faster than this.
Bpb
philk
Re: HDML
« Reply #19 on: July 16, 2011, 10:12:08 pm »
you may not be overpowered cruising speed of 9 iknots top speed 12 knots
LarryW
Re: HDML
« Reply #20 on: August 08, 2011, 08:55:59 pm »
HI ALL,    got back to HDML  any body no what Gray to use and was it GRAY it all over ?..........LARRY...
LarryW
Re: HDML
« Reply #21 on: August 16, 2011, 05:33:58 pm »
    HI ALL , BIT OF GRAY PAINT GOING ON  and lockers  and guns , really chuffed with scratch built guns............LARRY....
LarryW
Re: HDML
« Reply #22 on: September 01, 2011, 05:04:00 pm »
HI EVERY BODY,    a bit more HDML  paint work started ,  deck works on going ,  a bit more to scratch build , pram dingy nav lights anchor winch and stanchions all 42 of them ,
 but may buy them  unless got any no how , looking at you bluebird your build blogs have been helpful  pleased with life raft , bought one of mike race with some bits, made a copy  ,
 like mine better , just a bit more fine tuning all round , would any of you have a deck colour or leave as is b/w pics don't show what colour  they where.
      comments would help.......... :-))    LARRY
LarryW
Re: HDML
« Reply #23 on: September 27, 2011, 12:22:23 pm »
HI ALL ,  a bit more done,     just the fine tuning now , rigging kick boards, splinter mats , and of course the expensive  bit props and ESC   on the back burner till sell a couple
 of models to sponsor the build.     LARRY...
mikearace
Re: HDML
« Reply #24 on: September 27, 2011, 07:23:41 pm »
SPlinter mats in post Larry
