Author Topic: Single-core mains cable  (Read 3635 times)
dreadnought72
« on: June 11, 2011, 02:40:33 pm »
I've yards of single-core domestic mains cable left over from some DIY work.
What's the cons against using this for the power side of boat wiring? If it's good for 13A 240V stuff (around 3kW) is it necessarily bad for 5A 12V (60W) usage?
Andy (now the proud owner of some surface-mount spade fuse holders)
boatmadman
Re: Single-core mains cable
« Reply #1 on: June 11, 2011, 02:54:23 pm »
Andy,
No problem at all - massive overkill but so what?
I use it all the time for battery and motor connections.
Ian
dreadnought72
« Reply #2 on: June 11, 2011, 04:49:46 pm »
Thanks for the quick and positive answer, Ian.
Massive overkill = negligable resistance, I suppose!  %)
Reading more, the disadvantages of single core (skin effect at HF and "prone to metal fatigue compared to multicore") aren't issues for this purpose.
Many thanks,
Andy
« Reply #3 on: June 11, 2011, 05:27:45 pm »
Metal fatigue is down to its inability to go with the flow (Vibration) of stranded.
  Regards Ian.
andrewh
« Reply #4 on: June 13, 2011, 12:49:33 pm »
Andy
Tiny adder - the insulation is vinyl (PVC) and cheap and highly filled at that.  So keep away from heat (max 80 degrees)
I use it for fixed supplies in boats
andrew
dreadnought72
« Reply #5 on: June 13, 2011, 03:06:14 pm »
You take me back thirty years, Andrew.
I once messed up a Physics exam question which was based on a labelled photo of the inside of an insulated box containing 'electrics'.
The question was "Does Wire 'A' Require Insulation?" Wire 'A', I ought point out, apparently carried live mains. So I said "Yes", based on the fact that the cover was off and the photographer could have stuck his fingers in. %)
I still don't think I was wrong.  %%
Andy
andrewh
« Reply #6 on: June 13, 2011, 10:11:30 pm »
Andy
Bin there, got the academic tshirt
It used to be said at one alma mater that "Exams are nonsense; the greatest fool may ask more tham the wisest man may answer"
how goes big D and Racundra the skimming dish?
andrew
nick_75au
« Reply #7 on: June 15, 2011, 05:19:53 am »
Just don't try to run 3 Kw through it at 12 volts, It may not become a light bulb but it could go close %%
Nick
dreadnought72
« Reply #8 on: June 15, 2011, 05:30:56 pm »
 {-) If I should get 250 amps out of this battery, Nick, mere "temporary lightbulbs" are the least of my worries.
Andrew - big D is waiting until rotund R is sailing. I haven't the room to work on both, and there are costs ahead for the Dreadnought that I'm putting off for a wee while.  <:( Meanwhile, Racundra has her main wiring loom in, and I'm going to finish the insides (servo/winch location, linkages etc) before slapping the decks and cabin on. There'll be an update on Racundra in the next couple of weeks.
Andy
dpbarry
  • If it ain't broke, break it and curse fixing it!
    • Newcastle Lifeboat Station
« Reply #9 on: July 07, 2011, 04:05:29 pm »
Andy
Technically you where right   <*<  especially in todays Health and Safety madness >>:-(
Declan  :-))
Page created in 0.127 seconds with 22 queries.
