Ive been mucking about with the calculator and come up with a few figures to find the motor that was asked for
20 cells Nimh 55 mm racing prop,
The MMB 900
max amps 17.0, Watts in 395, out 308, RPM 10,837, 78.% efficient,,,,, Ok my 25 amps max was a little out
Plugging in a 55 mm Raboecsh prop gets this motor to its maximum efficiency and 11,000 rpm and 16 amps, Nice.
A 540 Kv brushless 42 mm motor equivalent Kv to the MMB 900
Max amps 21, watts in 487, out 465, rpm 12,105, 89.2% Efficient
a 440 Kv motor
Max amps 13.8, watts in 311.3, out 265, rpm 10,266, 85% efficient
A 330 Kv motor
max amps 5.9, watts in 145, watts out 115, RPM 8,026 79% efficient
Conclusion
A 440 Kv motor will give you about the same speed with lower amps
A 540 Kv motor will give you more speed at the expense of higher current draw
a 330 Kv motor will give the amps Andy asked for, slower but that is the maximum amps it will draw not the average amps.
Nick
