Author Topic: Footy Junk  (Read 5601 times)
rickles23
Footy Junk
« on: July 23, 2011, 08:21:08 am »
Just joined yesterday and it will take a few days to find my way around. I usually race Marblehead class yachts but recently I have been converted to Footy yachts.
I am currently building a Junk with two masts and I have struck my first problem. I need to rotate the masts using one servo.
n33h
Re: Footy Junk
« Reply #1 on: July 23, 2011, 08:52:11 am »
you could try using a 1 turn sail winch avaliable from most model stores but i think i got of few of mine from howesmodels.co.uk, you could also try cornwallmodelboats.co.uk
nick
nhp651
Re: Footy Junk
« Reply #2 on: July 23, 2011, 08:56:36 am »
good to see you on here rick.
although not knowing owt about yachts I think what you are after is some sort of mechanism under the deck for turning the mast around it's access
can any of you yachties help with either a diagramme or a way of mounting a mast on top of a servo.
neil.
n33h
Re: Footy Junk
« Reply #3 on: July 23, 2011, 09:24:18 am »
thanks neil, its good to be here, found some very interesting articles and some great advice on this forum
i mounted a perkassa forward bofors gun to a standard servo (wired into a harness to work with the rudder, rudder went left, gun went right)
i used a length (about 3") of 2mm connector rod, threaded end went into the servo and epoxied the other end into the gun, worked a treat and has not failed (yet !!)
so on that basis, he could do the same thing however, i would thread the other end aswell and screw into the mast bottom should work, it can be done with pretty much all servo's or winches i suppose !!
nick33
Nige52
Re: Footy Junk
« Reply #4 on: July 23, 2011, 12:16:07 pm »
I've just made 2 x air rudders from Correx which are connected via aeroplane type nylon rudder fittings, so when the servo arm pulls/pushes the one rudder, both of them move.....hmm, that sounds complicated, but it ain't!
PHOT0'S ON THIS THREAD
If the 2 masts have to swivel together, can't you connect them in the same fashion?
Just a thought.
Oh and welcome into the world of Footy's....my new one came today...that makes 5 of them  {-)
Patrick Henry
Re: Footy Junk
« Reply #5 on: July 23, 2011, 01:54:07 pm »
I thought you were taller than five foot, Nige?
I'll get me coat.... {:-{
rickles23
Re: Footy Junk
« Reply #6 on: July 23, 2011, 02:10:31 pm »
Thanks guys,
That has certainly given me some ideas and now to find some local (Australian) bearing suppliers.
LarryW
Re: Footy Junk
« Reply #7 on: July 23, 2011, 04:49:20 pm »
HI RICKLES, I USED A RUDDER TYPE SET UP ON MY BLACK ROSE,   linked to swivel masts set in base tubes with a rudder type horn set up.
 hope this helps LARRY.....
n33h
Re: Footy Junk
« Reply #8 on: July 23, 2011, 10:33:57 pm »
diagrams certainly help explaining things, looks very similar to a running line
been trying to find you on here larry, will be bringing the airboat to the meeting teusday (weather permitting)
i've posted some photos of the completed on here, its under scratch build airboat in the section
nick
andrewh
Re: Footy Junk
« Reply #9 on: July 23, 2011, 10:42:11 pm »
Hi, Rickles
I use a standard servo with 90 degree rotation - and fit a pulley to the servo arm about 1 inch diameter - this drives a half-inch pulley on each mast - so they rotate through twice the angle
Cord is just waxed twine, and the pulleys are
There were photos on the footy forum - have you discovered that yet?
http://www.rcsailing.net/forum1/forumdisplay.php?61-General-Discussion-(Footy)
andrew
rickles23
Re: Footy Junk
« Reply #10 on: July 24, 2011, 02:23:33 pm »
Hi all,
Along with the various suggestions and a flash of inspiration I have figured out how to do the rotating masts.
Whoever included a spell checker on this website deserves a medal.
Now to see if I can include a photograph.
nhp651
Re: Footy Junk
« Reply #11 on: July 24, 2011, 06:22:31 pm »
And not  a mention of what real junk rig is like Rick,  %% %%
enjoy your build mate.you're in good hands here, lol :-)) :-)) :-))
rickles23
Re: Footy Junk
« Reply #12 on: July 26, 2011, 09:01:54 am »
"And not  a mention of what real junk rig is like Rick"
Is that someone from SN by chance?... :-))
rmaddock
Re: Footy Junk
« Reply #13 on: July 26, 2011, 09:53:35 am »
I may be missing something, but surely the setup you have in your diagram would make the masts rotate in different directions.
I don't know about junk rigs but that doesn't seem right.
Re: Footy Junk
« Reply #14 on: July 26, 2011, 03:32:27 pm »
Both mast levers connected to the same side of the servo horn is the way to go
MikeK
  • Utter Bloody Chaos !!
Re: Footy Junk
« Reply #15 on: July 27, 2011, 09:27:54 am »
Me too !! Had to smile when I read the posts on SN, all with the best intentions of course. Now you have come to the right place !
rickles23
Re: Footy Junk
« Reply #16 on: July 31, 2011, 10:09:09 am »
Hi all,
You may be right about the way the servo is connected to the masts but plans from sepearate people show it set up as per the drawing.
I will let you know the results when I get to that bit.
andrewh
Re: Footy Junk
« Reply #17 on: January 15, 2012, 08:06:20 am »
Hi, Rickles
No, Rickles is in Australia , so everything is reversed and the masts will be (relatively) pointing downwards :} :}
Your levers will work - but only for a limited angle  - normally servos have about 90degress total travel and if all three levers are the same length the masts will also travel 90deg
In theory you can make the arms on the masts shorter, so that they rotate more angle - but there is a danger of the links binding or going over-centre
go for it!
andrew
