Author Topic: conectors  (Read 4544 times)
guitar man
conectors
« on: July 24, 2011, 07:04:45 pm »
Hi all
       Can anyone tell me what happens to these connectors,do they have a male opposite that you can buy or are you meant to crimp them over in some way, have not come across these sort before. I may just cut them off and connect in another way buy would be interested to know about them
        As always thanks in advance for any help
                                                        Regards Tony
david j
Re: conectors
« Reply #1 on: July 24, 2011, 07:10:06 pm »
 hi,
 are they on mtronks esc, if so they are bullet  connectors i normally cut them of and use spade ones as you said
John W E
  • I see no ships !!
Re: conectors
« Reply #2 on: July 24, 2011, 07:14:33 pm »
hi there
We used to know these as a 'bullet' connector - male and female - the one you show on the photo is the female.  Several companies such as MTroniks and Graupner use these connectors on some of their speed controllers.  The problem is if you cut them off you make your warranty on the speed controller invalid.  I have found Halfords sell a pack of varying sizes of the male and female which I have used.   They are pretty easy to crimp onto cable using a pair of pliers, but I have, in the past, used a small amount of solder to hold them in place.
aye
john
Knowledge begins with respect
john s 2
Re: conectors
« Reply #3 on: July 24, 2011, 07:45:46 pm »
I agree with bluebird. If you can soider them. I also use heat shrink over the outer wire onto the connecter to
ensure the wire holds ok if pulled or flexed. John.
guitar man
Re: conectors
« Reply #4 on: July 24, 2011, 07:56:14 pm »
HI David yes they are off Mtroniks sounds like you have been there before ,thanks to the others for your speedy response.
Regards Tony
david j
Re: conectors
« Reply #5 on: July 24, 2011, 08:40:23 pm »
hi,
i have sent one back and they didnt bother as the fault was inside sent replacement unit  great services can not fault them, yes been there you know the rest
davidj
thelegos
Re: conectors
« Reply #6 on: July 24, 2011, 09:00:39 pm »
Check out Flightline Accessories number HFL2025 bullet connectors, it's a pack of six male, six female and 12 plastic boots.
Roger
longshanks
Re: conectors
« Reply #7 on: July 24, 2011, 10:04:12 pm »
My sparky showed me some new connectors which are compact, simple to use and vibration proof - worth a look  :-))
http://secure.wago.ltd.uk/shop/department/222_series/
John W E
  • I see no ships !!
Re: conectors
« Reply #8 on: July 25, 2011, 08:25:51 am »
hi,
davidj
nick_75au
Re: conectors
« Reply #9 on: July 25, 2011, 12:32:17 pm »
It seems to me that is not saying a change of connector will void warranty, just that they wont cover changes to the connectors, ie if you change them they wont change the replacement ESC's connectors to what you put on. Could be wrong though {:-{
Its a standard connector Tamiya put on their motors \ Speed control, ordinary auto crimp bullets will work in them.
Nick
mike_victoriabc
Re: conectors
« Reply #10 on: July 25, 2011, 03:28:03 pm »
Bullet connectors over our way are quite common off the auto supply shelf - red and blue (wire size) - I use these quite often, just remember to add coloured tape to your wires if using for power where + / - is critical. The trick is to crimp these well - tinning the wire first helps.
Page created in 0.77 seconds with 18 queries.
