oh yeah that monoperm is like 42 quid new and people will still pay u good money for it. secondly what frequency radio you on? if you are 27 or 40 you will need to solder suppression caps on the new motor. if your 2.4ghz you wont need to bother. im afraid i cant help you too much with that bit instead of faffing about with suppression caps mi bought a 2.4ghz rc
27 and 40 is the old school way. ive just finished my first build and i got a 27 mhz transmitter. The amount of pis5ing about i had to do with it trying to over come interference and such i just bought a brand new FS GT2 transmitter and receiver. its cheap, its chinese, it works!!I Bought this one from this guy. its a little bit more expensive than getting them directly from china BUT it came the next day!! the china ones take weeks and if its faulty i dont have to airmail it to hong kong to get my money back!!http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=320730605812&ssPageName=STRK:MEWNX:ITdespite its simplicity it brilliant. 2.4 ghz means you dont need crystals, you dont need suppression, you dont lose signal. it doesnt interfere and have a fit when you fart near it.best money i spent so far!!
Unless you (or a mate)has access to a lathe, don't try to drill the coupling out. The basic sizes of Huco couplings have the red or black centre lump as standard and the Brass end bits are selected for bore of shaft and motor and then pushed into the ends. One of the better toy boat shops should have the manufacturers "Kit" to supply exactly to your needs. Regards Ian. http://www.howesmodels.co.uk/RadioControl/viewProducts.php?SubCatID=112
well if you dont get 2.4ghz use the suppression capacitors otherwise youl have problems. i dont know a lot about them tbh i got an idea of how to fit them and the type needed but no personal experience with them. when you install the motor make sure everything is running smoothly and the alignment is good. the UJ will alow sum flex in the angle but not in the alignment. bad alignment put unecessary stress on the bearing walls. post updates on how ur doing maybe sum pics if you can
