Author Topic: water cooling question...  (Read 2641 times)
Patrick Henry
« on: August 09, 2011, 03:52:54 pm »
Where's the best place to install the watercooling inlet pipe, chaps? (ignore the rudders, they are only temporary and will be replaced later by a pair of brass rudders)
Ta,
gwa84
Re: water cooling question...
« Reply #1 on: August 09, 2011, 04:01:35 pm »
there you go make sure they line up with your prop blades  :-))
Patrick Henry
« Reply #2 on: August 09, 2011, 04:10:09 pm »
So I'll need two inlets, will I? Is that one complete system for each motor?
Patrick Henry
« Reply #3 on: August 10, 2011, 07:57:49 am »
So...do I install two inlets and watercool each motor separately, or do I install one inlet and watercool both motors from the one inlet pipe?
« Reply #4 on: August 10, 2011, 09:46:16 am »
As it doesn't look like a racing boat, ie. the motors run hot.
 You'll probably get away with one larger water pick up.
 Just make sure that the outlet stream is clearly visible from the bank.
 I've Used to set mine up so it spurted upwards from the transom - like those water jet bikes!
Patrick Henry
« Reply #5 on: August 10, 2011, 11:51:12 am »
No, not a racing boat Martin, just a cruiser type boat with two 550's in it. I'm too old for racing now!  :((
Thanks for the reply,
ACTion
« Reply #6 on: August 10, 2011, 12:31:47 pm »
'Uggett
You won't need water-cooling with the 555 motors and 3-blade scale props you're going to use.
DM
Patrick Henry
« Reply #7 on: August 10, 2011, 12:48:30 pm »
Ah, the man himself...you have an email, young fella me lad.
