Author Topic: smoke help  (Read 2922 times)
helmsman
smoke help
« on: March 10, 2007, 05:45:35 pm »
Hi folks
Does any one out there in Mayhem land have a recipe for smoke oil (Destillate).
                                                         Terry (Helmsman)
Faraday's Cage
  • Change is inevitable, except from a drinks machine
Re: smoke help
« Reply #1 on: March 10, 2007, 07:28:30 pm »
Hi Terry (Good name that  ;D),
I've used baby oil for smoke oil in the past without any problems apart from the odd look from the cashier at Superdrug  :o
Terry (Faraday's Cage).
Re: smoke help
« Reply #2 on: March 11, 2007, 03:23:41 pm »
Disco fog oil from Maplins.
It is supposed to be nonflammable and non toxic.
You can also add aromatherapy oil to improve the smell.
helmsman
Re: smoke help
« Reply #3 on: March 12, 2007, 09:39:05 pm »
Thanks Guys
I will try both.
                  Terry
pakirk
    • www.rcmodelworkshop.com
Re: smoke help
« Reply #4 on: March 12, 2007, 11:31:11 pm »
I use the Maplin disco smoke flued, It's much cheeper than the modelshop stuff and works realy well.
White Ensign
  • Limits must be limited!
Re: smoke help
« Reply #5 on: March 13, 2007, 08:15:36 am »
Terry, by using only baby-oil you may have trouble after a while with soot. Additionaly it takes longer for the generator to produce smoke. Though I have found a mixture which avoyds soot and "cleans" the resistor which heats up the destillate- plus a very early smoke!
It is baby-oil and turpentine, mixed in a ratio 5:3. If you wish to have a speacial flavour, you may add one or two drops of flavoured oil. I use to take "Green apple", which makes any audiences smile as it seems a bit strange when a warship passes on by, smelling like an green apple...  :D
Hope this was out of any help.
Jörg
When God created planet earth, he made it with 75% of water. Bet he had the modelboaters on his mind!
Faraday's Cage
Re: smoke help
« Reply #6 on: March 13, 2007, 09:01:57 am »
Jorg,
Thanks for the advice. I'll give it a try.
Terry.
RickF
Re: smoke help
« Reply #7 on: March 13, 2007, 09:46:24 am »
Jorg,
What element/voltage setup do you use? Bought or home-made?
Rick
White Ensign
Re: smoke help
« Reply #8 on: March 13, 2007, 10:25:32 am »
Hi Rick, I use the bought items from Seuthe (wonder if it is known in the UK). There are various types which run with either 6 or 12 Volts. The advantage is, that they use a ceramic resistor which produces heat. The ceramic is shaped with a small tunnel, though the capillaries-effect "soaks" up the liquid, which will be overheated and produces the smoke.
I have made some tries with selfmade items, but hasn`t been very successfull as they also produce a greasy fog which will fall down on superstructure and deck and soil it.
Jörg
RickF
Re: smoke help
« Reply #9 on: March 13, 2007, 08:28:41 pm »
Yes, Jörg, Seuthe is available in the UK, from specialist model railway shops. Does the 6V system produce adequate smoke?
Rick
