ukmike...it really depends on the application
1. the coupling you display is designed to provide a resilience in motion between components in shaft rotation....not necessarily a shaft alignment issue
2. an example of the coupling design concept......could be to eliminate the impulsive characteristics of an internal combustion engine
For a high power electric application....best copy a typical coupling they use
.......Derek
