Technical, Techniques, Hints, and Tips > Radio Equipment
Rx batteries
<< < (2/2)
Scottie:
Hi Bigfella,
No, if you're using a BEC, you don't need batteries for any other servo that is connected to the receiver.
Scottie
Colin Bishop:
Dougal99 is quite right. As long as you have power in hand then you can run your RX off the main power supply. I'm just a bit old fashioned I guess! It's horses for courses really.
bigfella:
Hi Scottie
That has cleared up a problem that has been on my mind for a while. I was not sure if the BEC would run the rudder servo or not, also now knowing that I can save on weight with not having to put the Four AA's for the receiver in my PT Boat.
Thanks and regards Bigfella
Navigation
[0] Message Index
[*] Previous page
Go to full version
