May 22, 2025, 12:25:01 am
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Mayhem at Wicksteed -
May 24 25 2025
Home
Help
Search
Calendar
Login
Register
The Shipyard ( Dry Dock ): Builds & Questions
Submarines
release valve
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: release valve (Read 3478 times)
Andy_k
Full Mayhemer
Offline
Pembrokeshire
release valve
on:
September 01, 2011, 06:09:58 pm »
Hi can anybody tell me what is generally used to hold or release the water in a sealed ballast tank system ? as I know the pressure will push back past the pump.
Is it something I can make or is it a bought item ?
Right which one will I do next?
andyn
Guest
Re: release valve
Reply #1 on:
September 01, 2011, 06:21:34 pm »
I've used pinch valves, basically a servo pushes a steel rod into a block with the silicon tube from the pump through it.
You can either message Sheerline for one, or I'll make you one.
Andy
thegrimreaper
Guest
Re: release valve
Reply #2 on:
September 01, 2011, 06:26:04 pm »
try this link theire is a picture of what you need to make half way down the topic
http://www.modelboatmayhem.co.uk/forum/index.php?topic=28915.0
Regards Mark
thegrimreaper
Guest
Re: release valve
Reply #3 on:
September 01, 2011, 06:28:09 pm »
sorry the valve is on the left with the tubing going through it and an offset cam on a servo to open and close the valve plus strat the pump via the micro switch
Andy_k
Full Mayhemer
Offline
Pembrokeshire
Re: release valve
Reply #4 on:
September 01, 2011, 08:15:42 pm »
OK that seem straight forward Andy I am going to have a go at making one but may come back to you if thats OK
Mark do you use a standard servo on that or heavy duty ?
Andy
thegrimreaper
Guest
Re: release valve
Reply #5 on:
September 02, 2011, 08:32:05 am »
@ Andy_k
Chris from Sheerline recommends a ball raced servo which is what I use think it cost me about a fiver never had a problem with the system used Andy
Regards Mark
andyn
Guest
Re: release valve
Reply #6 on:
September 02, 2011, 03:31:13 pm »
Futaba S3004 or S148 will do the job perfectly
Davy1
Guest
Re: release valve
Reply #7 on:
September 03, 2011, 09:07:03 am »
You may find this discussion thread useful (Several different methods + design principles reviewed:
http://www.theassociationofmodelsubmariners.com/t380-pinch-valves
Andy_k
Full Mayhemer
Offline
Pembrokeshire
Re: release valve
Reply #8 on:
September 03, 2011, 04:48:35 pm »
thankx Davey thats got my mind going now got to say I like Gantus idea so simple and small
Andy
Print
Pages: [
1
Go Up
« previous
next »
Submarines
release valve
