Author Topic: Tell me the running gear 1.2meter maxicat?  (Read 4260 times)
neilb
« on: September 03, 2011, 03:13:28 pm »
Hi ppl, i am going to be building a maxi cat 1.2 meter and was wondering what power plant i should put in the boat, i am wanting brushless prob twin set up really and has to be fast not to be slow this is important, Can some one please come up with the full running gear for thin including rudder set up prop and tub set up as well as all the electric
Many thanks
pompebled
Re: Tell me the running gear 1.2meter maxicat?
« Reply #1 on: September 03, 2011, 04:16:16 pm »
Hi Neil,
If you have no clue as to what to power such a large cat with, I suggest you do your homework and make sure that you are aware of the costs involved.
Making a twin cat go (really) fast may add up to a thousand or two...
Regards, Jan.
Boaters are nice people
martno1fan
« Reply #2 on: September 03, 2011, 05:13:24 pm »
Hi this is one of my 58" navaho hulls shes powered by twin himodel  outrunners on 6s lipo, each motor cost only $59 the esc are not expensive ones eiether,id say the whole setup cost arround the same price as a modded zenoah.Why not have a look over on offshoreelectrics and see what people are using on theres or similar size cats.Also i have a small cat mould similar to the mystic cats if your interested in one let me know shes 37" long.
Mart
http://www.youtube.com/user/RangerPate#p/u/6/MKNt2t__uAE
http://forums.offshoreelectrics.com/
neilb
« Reply #3 on: September 03, 2011, 06:59:34 pm »
Mart
Many thanks for the info i am looking at stuff all the time but there is that much on the market it could take me years to come to terms with this tec...
MikeA
« Reply #4 on: September 03, 2011, 11:00:26 pm »
have you got the cat? whats your budget?
martno1fan
« Reply #5 on: September 03, 2011, 11:08:47 pm »
Neil unless you have built a boat before i wouldnt even attempt a maxcat,its not a straight froward build cats are complicated.If you want to build your own hull from plans then id suggest the deep vee hull 48" long called the prowler.Or why not a kit such as the easy vee from zippkits its lazer cut and so easy to build and they run really great.
Mart
http://www.zippkits.com/
neilb
« Reply #6 on: September 04, 2011, 06:51:11 pm »
i have no budget really fella what ever it will cost so be it as long as i dont have to re mortgage the house lol
neilb
« Reply #7 on: September 04, 2011, 06:55:26 pm »
Mart
I know it will be difficult but i am joiner and no wood project can be hard for me see ppl do them who i know and does seem straight forward, yes there will be little ups and downs but that is what the forum of for to help ppl, i have thought about the prowler which i have the plans for just just prefair the cat to that really, i would say i like a challenge  and like to be thrown in at the deep end, If the build dont work it is only wood at the end of the day really
I am thinking more along the lines now of just a big single brushless etc till i get my head around the twin systems...
MikeA
« Reply #8 on: September 04, 2011, 08:47:05 pm »
well i suppose the build of the boat itself depends on your crafting abilities, weather your scratching builidng either mono or cat the build is the easy bit. Its the drive systems and setting up that gets complicated. to power a cat like that crikey your gonna need sum big motors, if it was me id use:
2 of these :
http://www.ebay.co.uk/itm/Leopard-4082-brushless-marine-motor-RC-boat-2000KV-/170690016240?pt=Radio_Control_Parts_Accessories&hash=item27bdeaf3f0
2 of these :
http://www.ebay.co.uk/itm/SEAKING-Electronic-Speed-Controller-180A-ESC-Boat-/180427869753?pt=UK_ToysGames_RadioControlled_JN&hash=item2a0256ce39
2 of these :
http://www.hobbyking.com/hobbyking/store/__10303__Turnigy_4000mAh_4S_40C_Lipo_Pack.html
1 of these :
http://www.hobbyking.com/hobbyking/store/__6478__IMAX_B6_AC_Charger_Discharger_1_6_Cells_GENUINE_.html
to charge the lipos youl need the balance charger. cant use  normal charger.  your gonna have to look at the hardware to thatl be another £140 lol
wish i had money like you for my boats !!
MikeA
« Reply #9 on: September 04, 2011, 09:34:10 pm »
lol i cant help much really the size of this boat is unfathomable.  I wouldnt take my word for it on that list. itl need checkin buy someone, just my oppinion.
if your going down the single drive route you would need possibly a 60-70 mm prop. youl need a monster of a motor for that like 6050 1800kv outrunner or something.
this for example:
http://www.mtroniks.net/details1.asp/ProductID/720/sid/66/ACI243productpage.htm
dont know if its fast enough tho
MikeA
« Reply #10 on: September 05, 2011, 12:17:52 pm »
heres a vid of cat the size you want to build with dual 5692 leopards and 6s
pompebled
« Reply #11 on: September 09, 2011, 06:12:57 pm »
Page created in 0.047 seconds with 21 queries.
