Author Topic: Brushless motors, lipos and esc mixers.  (Read 2955 times)
justboatonic
« on: September 06, 2011, 06:31:22 pm »
Now that Dirty Harry, the MSW Envoy build is virtually complete, Im contemplating the next build which will likely be twin screw and a decent size ie 1\72nd scale warship, 1\48th scale Minehunter or 1\12th scale Tamar
I want to use lipos as Im using them for leccie flight and want any new purchases to become interchangable if possible.
Like most people I guess, I can obtain lipos, brushless motors and esc's. But, if Im going down the twin screw route would like to maintain mixing ability to slow the inside prop in a turn. I dont want to go down the 'tank steering' route as I prefer the steer wheel transmitters for sailing.
So, with a likely lipo power source of 6S packs ie 22.2v for something like the Tamar and 4S packs ie 14.8v for warship \ minehunter, does anyone know of available mixers that can handle these voltages? All the ones I've seen only seem to handle 12v.
suggestions greatfully recieved  :-))
treeboa
Re: Brushless motors, lipos and esc mixers.
« Reply #1 on: September 06, 2011, 06:56:15 pm »
i always thought mixers and such worked off the same voltage as the receivers - certainly not 12v or anywhere close to that
justboatonic
« Reply #2 on: September 06, 2011, 07:13:52 pm »
ESC's and mixers need to handle the voltage of the motor batteries though dont they!?
treeboa
« Reply #3 on: September 06, 2011, 08:25:40 pm »
the esc handles the battery to motor voltage, the red lead on the esc supplies the correct lower volts to the rx on a bec system, the rx sends the power to the units that it  controls, esc, servos, switches etc, typically 4.8 - 6 volts
« Reply #5 on: October 08, 2011, 09:37:25 am »
Mixers work on the output from the receiver, taking information from two channels and mixing them.  They then take the mix and re-transmit it to the ESCs, which think they are still plugged into the RX.  The mixer runs off the same supply as the receiver, being part of the logic/control train.  Until such time as ESC manufacturers start making brushless ESCs that offer reverse in the same way that brushed ones do, mixing is probably best avoided.
4-8 to 6 volts, yes-ish.  The instructions do need careful reading regarding the type of battery supplying the voltage.
andyn
« Reply #6 on: October 08, 2011, 11:21:23 am »
Pm sent :-))
Page created in 0.05 seconds with 21 queries.
