Author Topic: Soverign Models Lady Sarah  (Read 3328 times)
redpiperbob
« on: September 13, 2011, 07:52:35 am »
Hi  All
I have a Soverign Models Lady Sarah and would like to fit it out with a steam plant (not very big)
can anyone recommend a plant for such a small boat.
thanks
kiwimodeller
Re: Soverign Models Lady Sarah
« Reply #1 on: September 13, 2011, 11:38:37 am »
I have a Lady Sarah fitted with a Saito V4 which is a neat little engine but no longer made sp you would have to look on Ebay. Of the engines which are still available I think you could drive her well with the SVS engine from Tony Green Steam Models. They are available with either 8mm or 10mm bore and are 12mm stroke. They are double acting and self starting forward and reverse with a built in control valve so you could get away with just a 2 channel radio. The website is currently being redone but you can email them at [email protected] or ring them on 01522 681989. A 6" x 3" boiler would be ample and will easily fit in the Sarah hull. I bought mine of Ebay but the workmanship was so bad I built new cabins from the Miranda plans. Photos of the SVS engine and my boat are attached I hope. Hope this helps, Ian.
redpiperbob
« Reply #2 on: September 13, 2011, 08:28:05 pm »
Hi Ian
Thanks for the reply The SVS is exactly the sort of engine I am looking for. Email sent to Tony Green Models
Your boat looks very authentic  .
redpiperbob
« Reply #3 on: September 20, 2011, 07:28:11 am »
Hi All any more suggestions. No reply from Tony Green Models
Thanks Bob
kiwimodeller
« Reply #4 on: September 20, 2011, 10:48:52 am »
Bob, the email address I gave you was from their new web site so may not be up and running yet. I bought some engines from them a few weeks ago and corresponded with Joan Green at [email protected] so try that one. Cheers, Ian.
redpiperbob
« Reply #5 on: September 21, 2011, 06:50:18 am »
Thanks Ian will do
