Author Topic: Buoyage  (Read 5899 times)
Jimmy James
Buoyage
« on: September 13, 2011, 07:00:58 pm »
 In our club we have started using the IALA systime of Buoyage.  Why ? because it makes it more interesting and I get fed up with people asking me which way  the wind is blowing and I tell them North they say which way is north  ...Dong... The IALA systime is based on 4 Cardinal points ---North, East, South & West each with its own top mark
 and also channel buoys that are Red and Green, Entering a river or channel Red Buoy is to port Red to Red ...and the green buoy is to stb'd ...Green to Green  leaving it's the opposite way around  If you pass a north cardinal buoy --you pass to the north of it  and so on sound confusing, not really I know some really dumb stick and string merchants who learned it and even they say its easy
the photo has some buoys in it (the Red & White one is the fairway buoy
Jimmy
Retired  Ships Officer/ Master.
Experience: 50+ years at sea under Sail, Steam & Motor
Kings Lynn
Jimmy James
Re: Buoyage
« Reply #1 on: September 13, 2011, 07:35:30 pm »
Making a north Cardinal Buoy    The buoy is a cistern float   the cage is 1.5mm wire   the mast is a bamboo dowel  The top marks are 32nd ply ( a tip the points on the top mark point to the black part of the buoy ie; North buoy points up  the buoy is yellow at the bottom and black at the top)
Kings Lynn
Jimmy James
Re: Buoyage
« Reply #2 on: September 13, 2011, 07:42:54 pm »
Kings Lynn
Jimmy James
Re: Buoyage
« Reply #3 on: September 13, 2011, 08:03:10 pm »
 {:-{ :(( >:-o >>:-( Time to knock off my hands are starting too cramp up)
 I'll finish up tomorrow   If any body whants to learn about the IALA International systime of Buoyage Google the underlined
 Jimmy
Kings Lynn
carlmt
    • Linkspan Models
Re: Buoyage
« Reply #4 on: September 13, 2011, 08:10:38 pm »
Excellent postings Jimmy = I knew this forum was educational!!!!
Carl
Re: Buoyage
« Reply #5 on: September 13, 2011, 08:25:01 pm »
Certainly worth putting it up.  Thank you Jimmy. I learnt something today.  O0
Trooper63
Re: Buoyage
« Reply #6 on: September 14, 2011, 02:47:48 am »
Nice work Jimmy.
If you find a way to get them to flash their correct sequence can you let me know.  I have made desk stand models using styrene, and they flash, but at this stage only a simple sequence.  I haven't been able to find any circuitry to replicate the true sequence.
Re: Buoyage
« Reply #7 on: September 14, 2011, 08:35:09 am »
Remember that in the USA, Canada and I think South America, the reds and greens are the other way round!
Talisman
Re: Buoyage
« Reply #8 on: September 14, 2011, 08:50:06 am »
Also, and i could be wrong, when doing my theory papers (it was a long time ago) is there not an exception to the rule somewhere on the (uk) South Coast ... or was that tides ...?
Kim
pugwash
Re: Buoyage
« Reply #9 on: September 14, 2011, 09:20:20 am »
Colin you are correct - N and S Amercias plus Japan and the Phillipines are in IALA area B
Kim are you thinking of the strange tides and a double high tide in and around Southampton water.
Geoff
Jimmy James
Re: Buoyage
« Reply #10 on: September 14, 2011, 07:59:52 pm »
Geoff Thanks
You saved me a lot of typing.
 Diagram of the moorings We use to follow.
Kings Lynn
Re: Buoyage
« Reply #11 on: September 14, 2011, 08:14:47 pm »
Yes, obviously you can enter the Solent from the west or via Spithead from the east. At some point you have to remember whether you are coming or going but I can't remember exactly where. But the main shipping channel is clearly buoyed and the watchword is to stay out of it unless crossing and then nip over as quick as you can, dodging behind anything large in transit.
Jimmy James
Re: Buoyage
« Reply #12 on: September 14, 2011, 08:18:46 pm »
These are the moorings we use , the counter weight keeps the slack out of the moorings so boats passing close too, don't snag it and as our buoys  stay out most if the year it allows for the rise and fall of the lakes level due to heavy rain fall or farmer Brown pumping water to water his fields
This will be the last post from me on this subject  unless anyone has any questions in which case I will do my best to answer  :-))
Kings Lynn
Jimmy James
Re: Buoyage
« Reply #13 on: September 14, 2011, 08:34:56 pm »
Trooper63
 RE; timing of Buoy lights
 I have seen a small horozontal wheel with contacts glued on the top of it as the wheel slowly turns it touches  a wire strip and the light flashes according to the grouping of the contacts
Jimmy
Kings Lynn
Trooper63
Re: Buoyage
« Reply #14 on: September 14, 2011, 10:49:50 pm »
Excellent idea, I had not been thinking on those lines but that should work.  Thank-you.
steamboatmodel
Re: Buoyage
« Reply #15 on: September 15, 2011, 02:39:39 am »
IALA Maritime Buoyage System
Navigation Aids
http://www.nauticalissues.com/en/iala.html
Gerald
Jimmy James
Re: Buoyage
« Reply #16 on: September 15, 2011, 07:29:45 pm »
 Troopes63
 The old ways are the best at times -----lots of small light houses  used that systime ( Mostly clock work) when electric power came in fof the lamps
 Jimmy
Gerald
Thanks for posting the address
Jimmy
Kings Lynn
