Time again for another minor "challenge", the "Stemhead Roller" assembly. I wanted this to be able to hinge, as the original, so the tow strops can be clearly seen running underneath it, plus it makes it easier to put the cables in later, now that I have managed to perfect the manufacture of the inner cable eyes for the strop ends [see earlier post].
I first cut some simple pieces of flat plasticard, then after gently applying some heat, sufficient to "soften" the plastic, I then "shaped" the plasticard around the forward/bow rubber fender to get a profile that replicates the ovalness. this was set aside to cool, whilst I then cut the flat deck pieces. I then plasticwelded the two pieces together and once dry, added some plasto filler to the join line, for careful sanding off later once fully dry. the roller assembly starts off with a simple square flat base plate, with an inverted "U" shape on the top [with a flared outer end towards the bows.]. The U shape was easy enough to shape, again using heat on some plasticard strip, this was cut to correct height and bonded to its base.
The hinges are pieces of hollow plastic tube, capable of allowing passage of a plastic "pin" through later.
The roller itself I made from a piece of wooden dowel rod, not having any plastic rod of suitable diameter, having used several "knitting needles" on an earlier project, I had none left !
But again, by slowly rotating the dowel, a round file was easy enough to use to add the shaped cable though.
I small drill was run through the centre point of the dowel, once cut to size, to allow a pivot rod to go through it and the roller frame.
I then heat shaped a front/bow piece to add on the the roller assembly, to guide the cable hawse, over the split gap in the lower sections. This piece was cut so as to run inside the roller, so the join did not show.
The 2 earlier made fender covers were added to the deck and the roller assembly, placed in position, so the deck halves of the pivot pieces could be bonded in place, by using plasticweld, for both ease and quickness of bond.
I have just got to make the rounded face for the roller assembly now, Ive made a wooden former, from which I will make it from.
