Not actually done any work on the Mersey today, but was collecting "bits" for it, as I'd placed an order with "Mac's Mouldings" and decided to collect from the International Model Boat Show. well, i wanted to go to the show anyway, so why not advance order the bits and pick up whilst there, at least i saved on postage [ha ha].
So I now have the interior cabin seats, I admit they are not "correct pattern" for a Mersey, but look similar and if i install minus the seat bases supplied with them, and simply make up the lockets they sit on instead, they should do the trick.
I also bought some lifebelts, some rectangular floats, some deck light shrouds [not pictured], a liferaft to sit under the flying bridge floor, some radio and electrical panels and some resin bollards, to loose some weight by not fitting the white metal ones, same goes for the towing posts too, resin will replace metal for weight shedding.
I also picked up some "D" section rubber fender strip from Models by design too, so this can be applied to the hull in due course.
Oh yes, one other, er "small item", simply for amusement, a "seagull", could not resist and once painted, he should sit quite happliy on the radar masting somewhere..............
