Author Topic: rescaling plans 1/20 to 1/12th  (Read 3453 times)
gregk9
    • Chasewater Model Boat Club
« on: October 09, 2011, 11:44:47 am »
I know and appreciate this has been put on this site many time, but cant find sight anywhere, so any assistance will be appreciated.
I have a set of plans, drawn to 1/20th, whats the conversion to scale up to 1/12th please.
Best wishes.
Steve. G.
Treasurer & Membership Secretary:  Chasewater Model Boat Club
http://chasewatermbc.blogspot.com/
TailUK
Re: rescaling plans 1/20 to 1/12th
« Reply #1 on: October 09, 2011, 01:01:05 pm »
If memory serves you should enlarge 1/20 plans to 166% to get 1/12 scale.
The reasoning goes like this.
1/20 = 15mm to the foot (300mm)
1/25 = 25 mm to the foot (300mm)
25 divided by 15 = 1.66
Any 1/20 scale dimension multiplied by 1.66 = that dimension in 1/12 scale   {:-{
gregk9
« Reply #2 on: October 09, 2011, 01:09:45 pm »
many thanks for your prompt reply.
Best wishes.
Steve. G.
sentry
« Reply #3 on: October 09, 2011, 01:17:14 pm »
hope you don't mind me tagging along on this one but  there do i find a chart to tell you all the differant conversions as i used to have one but lost it am wanting to change one from 1:64 to 1:32 which i think should be 200%  can anyone comfirm this please and where I may find a chart.
                  Regards, Howard, (sentry)
TailUK
« Reply #4 on: October 09, 2011, 01:59:35 pm »
If you google for scale conversion charts you should find quite a few. However most don't cover 1/64 to 1/32 cos it's a bit of a "no brainer".  Rescaling should just be a matter of doubling the dimensions or as you said, enlarging by 200% .
When it comes to rescaling another option would be "Proportional Dividers" These are double ended dividers with a movable pivot.  This allow them to be set to give a given ratio
michael 1979
« Reply #5 on: October 10, 2011, 04:29:56 am »
Its easier for me to do it this way.
If your dimension is for example 2.4 long.
And the current scale is 1/20 then, multiply the dimension by 20.
2.4 * 20 = 48
If the desired scale is 1/12 then divide by 12.
48 / 12 = 4.0 which is the rescaled dimension.
Or dimension = 2.4
Scale = 1/64
2.4 * 64 = 153.6
Desired scale is 1/32.
153.6 / 32 = 4.8
Use what ever units you like just keep it the same throughout.
I usually put everything into a spread sheet because its easier.
brianB6
« Reply #6 on: October 10, 2011, 05:10:23 am »
You should be able to get them enlarged at a Plan Printers.
There are special plan printers that enlarge architects etc. plans.
Page created in 0.024 seconds with 21 queries.
