Reg, transfer info well received and much appreciated thanks.
I don't seem to have achieved much since the last post. I have spent a lot of time just sitting and thinking. More time just sitting!! Also I keep having to go to Aldi/Lidle (Adle) to buy things on special offer. Today was the bench grinder. I gave mine away years ago thinking I'd never need one again.
So, made up and fitted bottom boards.
They are removable for cleaning under.
Then I made a doubler for the transom. Here's the rub. The full size boat hasn't got one. The side elevation hints at one but I thought maybe a thin veneer of mahogany on a cheaper wood until I noticed the rudder pintles are set into the transom so must be a doubler???
The end elevation shows no doubler either but it also shows no geralding which full size boat has.
Decided that as I had been forced to extend the transom upwards due to making a radish of it when I built it into the hull, I would fit the doubler which covers my error nicely. I made a card template of the transom as is and transfered the doubler outline onto a frame of mahogany glued up so as to get the grain in the right directions.
Cut it out on the scroll saw and pinned and glued it to the transom.
In between all this I made a few brass fittings on the lathe.viz the jackstaff, foremast and ensign staff sockets.
A kind mayhemmer is making me an engine driven feed pump, so I have ditched the oversize and cumbersome servomotor driven pump. I have returned the burner to the vertical position to make space for the pump to be driven off the forward end of the crankshaft. I had planned to redo all the pipework anyway so no loss.
And finally, I made a start on the deck by making a former to laminate the fore and aft deck beams on.
I'm laminating rather than steaming, because the sheerline moved a bit when I put the sheerclamps in. I only got one side in on one day and had to leave it overnight and this has resulted in a slight distortion which I think I can pull out/in when I fit the beams.
The recent post about the need to lay a ply subdeck has got me worried cos I was going to fit the deck planks without one as on the fullsize boat and have not left a space for it. Anyone successfully done it without a sub-deck? Was horrified to see one used on the Cutty Sark the other day!! I suppose though one must move with the times?
