January 05, 2026, 12:28:44 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Model Boating
Nozzles + props...
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: Nozzles + props... (Read 2650 times)
Patrick Henry
Guest
Nozzles + props...
on:
November 19, 2011, 11:36:00 am »
Any of you fellas tell me how far the prop needs to be inside a steering nozzle to work properly? Mine is about the same as in the attached diagram...is that about right?
Ta,
Full Mayhemer
Offline
Newport. S Wales
Re: Nozzles + props...
Reply #1 on:
November 19, 2011, 11:42:00 am »
The problem would come when the steering nozzle turns. Part of the propeller would then be outside the inducted water in the tube.
The ideal place would be dead centre of the depth of the nozzle.
(maybe
ken
Despite the high cost of living .......... It remains popular
Global Moderator
Full Mayhemer
Offline
You bark - I will bite!!!
Ivverkip, Inverclyde.
Reply #2 on:
November 19, 2011, 11:49:48 am »
Rich,
It is usual to have the prop either 1/3 or 1/2 way into the Kort.
1/2 way for manouverability (thrust and steering astern) 1/3 for ahead efficiency as this allows the Kort to have an aerofoil section which increases thrust.
Patrick Henry
Guest
Reply #3 on:
November 19, 2011, 11:53:34 am »
Ok, that won't be a problem, I have a good 1/2" of prop shaft length to play with, so I can have the prop further inside the nozzle.
Thanks Bob & Ken, much appreciated.
andyn
Guest
Reply #4 on:
November 19, 2011, 12:00:13 pm »
Tips of the blades should be directly underneath the steering post.
In ASD drive the props are right at the back, but the nozzle doesn't steer around them.
Print
Pages: [
1
Go Up
« previous
next »
Model Boating
Nozzles + props...
